![]() | Home > Maintenance & Modifications > Td5 turbo upgrade? |
Understandable. If I had the funds I would have gone down the VGT turbo route because the drive would have been smooth and progressive. Alas I did not and so could not. Instead I replaced the turbo CHRA with an uprated one with bearings and billet vanes etc. The effect was noticeable right from the off with a quicker spool up and power all the way up the rev range. With the addition of an Alive remap it is a good setup and works well. As with your Defender, Miffy is roll caged and often full of gear, she has over 200k miles on her and still pulls beautifully.
This is the CHRA I replaced https://www.turborebuild.co.uk/webshop/pro...ridge.html It is a good solution if you are willing to DIY... |
sharkey964 Member Since: 05 Oct 2014 Location: On a muddy track Posts: 577 ![]() ![]() ![]() |
Have you shortened the length of the actuator rod?Standard length is with 12 to 14 threads showing,you can safely shorten it to 9 threads showing,but,if you go too short it may go to limp mode,so just turn it back a couple of threads.
As I understand it,this increases the boost earlier. Marc |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2192 ![]() ![]() |
Id suggest speaking to Empire about a hybrid. Probably wont need a VNT/VGT as his hybrids are pretty big anyway. They also spool super fast! Also much cheaper than the VNT/VGT options. Instagram @defender_ventures
Empire Tuning - Agent |
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 ![]() ![]() ![]() |
Speak to Gary at Alive. He will be able to supply everything and tweak your map to suit. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp Roy |
andy2111 Member Since: 17 Oct 2021 Location: Kent Posts: 368 ![]() ![]() ![]() |
Agree with the last post.
If you have an Alive remap then speak to them about an upgraded turbo because they offer a couple of options. Importantly, they can put it on their Dyno and adjust your map to compliment the turbo. For best results these things are better off tuned together rather than having them treated as isolated upgrades |
Ghound Member Since: 03 Jul 2018 Location: northern ireland Posts: 45 ![]() ![]() ![]() |
Thanks for the advice folks
