Home > Technical > Help! Loss of power, boost leak? 2.2 TDCI
Andy RV
Hello all,
My 2014 90 lost power yesterday, I managed to limp it home but it’s pretty gutless.
The yellow engine light is on, it makes a whining sound from the passenger side when it comes onto boost, as if it’s leaking somewhere. No smoke, it fires up and idles fine. I’ve taken the hoses off today between the turbo to intercooler and intercooler to throttle body hoping to find a split but the hoses all appear ok. I’ve had a quick look at the intercooler and can’t see any bulges or bursts.
Would it be worth checking the throttle body to inlet manifold gasket? I’ve read a few threads where the gasket has failed between the exhaust manifold and turbo, while I’ve not taken the heat shield off I can’t detect and leak there and the turbo appears to be creating pressure so it’s perhaps not the issue?
Here’s a poor video of the whining sound;
Any ideas?
Post #939033 23rd Jan 2022 4:44pm
dorsetsmith
check charge air pipe work engine bay for splits or disconnected hoses good place to start and check DTC from ECU
NO throttle body but this a ford engine and junk to boot
Post #939037 23rd Jan 2022 5:02pm
Roy5695
Do d you check all 3 hoses?
There’s a little 90degree elbow one. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #939054 23rd Jan 2022 5:51pm
Martin
Site Admin
If it's passenger's side it's highly likely to be the elbow under the throttle body (yes, 2.2s have one!) on the inlet manifold side.
Get your hand underneath it and prod the hose to see if you can open up a split. Impossible to visually inspect it as it's buried behind coolant pipework.
You won't get any smoke due to the DPF.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #939056 23rd Jan 2022 5:55pm
Co1
See here for mine recently. Split couldn’t be seen, it was in the underside of the hose. Sounded just like yours though:
https://www.defender2.net/forum/topic81670.html
Post #939061 23rd Jan 2022 6:08pm
Co1
Here:
When changing it, I decided not to remove the coolant hoses to save time, but it probably cost me more time by not doing so. Give me a shout if you want any hints and tips.
Post #939062 23rd Jan 2022 6:10pm
Andy RV
Cheers guys, I’ve removed the three hoses, including the 90’ elbow which joins the throttle body and they all look fine. I’ve cleaned them up and done my best turbo impression by blowing through them in the kitchen sink while blocking the other end with my hand and I can’t detect any leaks or splits…! I’ll see if I can borrow or buy a code reader tomorrow😟.
Post #939069 23rd Jan 2022 6:41pm
Co1
“ done my best turbo impression by blowing through them in the kitchen sink”
Rolling with laughter Rolling with laughter
Post #939071 23rd Jan 2022 6:51pm
JPE
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Firenze Red
I've had 3 separate boost leaks with limp mode in 3 years. Once the hose into the inlet manifold, once the hose out of the intercooler, but the other time it was a split in the intercooler itself. Might be worth checking if all 3 hoses are ok.
Post #939083 23rd Jan 2022 7:35pm
piechipsandpeas
Australia 2013 Defender 110 Puma 2.2 SW Indus Silver
Hey Andy RV
It is very hard to ascertain where the hole is as it only makes the sound when the engine is running under load (ie when the turbo is spinning).
You can find the leak with the engine off by using a piece of plastic pipe, blanked at one end with a cap (cap needs to be glued on). A scrap valve (from a bike inner tube) is first fitted through a hole in the blanking cap prior to gluing the cap onto the pipe. Leave a bit of a flange on the base of the valve (you wont need any glue to hold the valve as the air pressure will seal it as long as its a tight fit).
Disconnect the boost hose from the turbo outlet and connect the plastic pipe to the boost hose. Then pump in air using a bike pump. When the system starts to pressurise you should clearly hear where the air is escaping (you shouldn’t need too much pressure).
Andy
Post #939182 24th Jan 2022 11:40am
geobloke
Love the test rig Andy Thumbs Up Thumbs Up
Post #939185 24th Jan 2022 11:43am
Andy RV
Brilliant! I’ll knock one of those up!
I put the hoses back on last night, I’ll take it for a run later today and see if I can narrow down the symptoms.
Post #939210 24th Jan 2022 1:31pm
Andy RV
Progress thanks to Andy’s pipe & pump pressure thingymajiggy! The intercooler has split;
Post #939259 24th Jan 2022 6:48pm
Co1
Nice bit of problem solving there! Good excuse to buy yourself a fully welded uprated intercooler as well!
Post #939271 24th Jan 2022 7:33pm
Ianh
What a great tool, simple , yet brilliant and cheap Bow down
What size pipe did you use ?
Post #939283 24th Jan 2022 8:28pm
