Home > Maintenance & Modifications > 110 Utility - Rear load area protection
Gal Dove
Wales 2014 Defender 110 Puma 2.2 USW Corris Grey
Hi everyone. I have a 2014 Defender 110 Utility that use for work, etc. I've been meaning to add some protection to the rear load area as I occasionally use it for logs and other heavy, unstable items that might damage the sides and floor of the load area.
For the floor I've been looking at the fitted rubber floor matt kits that companies like Lucari make. These are around 3mm (I think - haven't confirmed this with them yet) and would add a much needed extra layer of protection to the floor. The advantage is that these have already been cut to size for the vehicle and should be relatively easy to fit. I think that I could probably do this job for a fraction of the price if I just bought a roll of 3mm or 5mm rubber matting - but these kits do look neat and the car is mint so I'd like to do the best job that I can.
I'd also like to add some thin ply wood to the sides - maybe around 3mm or 5mm ply - I would plan on just buying a sheet of ply and cutting it to size. I would like to remove the plastic surrounds/mouldings and cover the whole area with the ply - and then replace the mouldings over the top after I've fitted the ply.
Does anyone have any experience of carrying out these job and is anyone aware of whether there are any online site that might be able to help me with cutting the ply to the correct size, etc.?
If possible, I'd also like to add some sound deadening/protection underneath the rubber floor matting and behind the plywood - if there was enough space(?).
Any help or pointers on any of the above would be very much appreciated.
Post #938867 22nd Jan 2022 6:18pm
newton-tony
United Kingdom 2014 Defender 110 Puma 2.2 USW Firenze Red
Hi. I did very similar to what you are suggesting in my 110 Utility.
I used Noise Killer (bought a rear protection kit), then covered with 12mm ply. Just measured and cut to size, with a few cut outs for rear seats etc. I then covered this with a rubber mat (glued) for protection against logs etc.
After a while, I decided to box in the wings and just used 12mm ply over the Noise Killer and again covered with rubber matting.
Finally, as a much cheaper option to the excellent drawer systems that are available, I used some left over OSB and bought some perfectly sized 'Really Useful Boxes.
A few photos, which may help. Good luck Smile
Post #938874 22nd Jan 2022 7:06pm
Gal Dove
Hi Tony - many thanks!
I'm not sure that my DIY skills are as good as yours but it certainly has given some food for thought! I think that I'd probably use a slightly thinner ply - maybe around 5mm - as the things that I tend to carry are relatively light.
It's the side panels that I'm really keen to cover as I use a builder's ton bag to gather logs, and they sit quite high up when the bag is getting full. I appreciate that I can always put a net over the top but those side panels are very vulnerable and it wouldn't take much to put a dent one! I've been lucky so far but it's time to put some ply over them before I regret putting this off any longer! Thumbs Up
I've been wondering whether there might be any resources on-line that might have the templates / measurements that I'd need to make sure that I don't waste a load of ply by making poor cuts!
Post #938879 22nd Jan 2022 7:43pm
newton-tony
Another option if most worried about the sides?
https://www.mudstuff.co.uk/products/mud-11...trim-panel
Post #938884 22nd Jan 2022 8:13pm
Gal Dove
Mmmmmm....thanks Tony! I'm assuming that these are the ones that you appear to have on your 110(?). They do look neat - do they live up to their price(?!) Very Happy
Nice that they come with some sort of foam deadening as well - although I assuming that it isn't as sound proofing as the real stuff?
Post #938885 22nd Jan 2022 8:21pm
If you want to fit ply to the side panels and then refit the trim over the top then there isn't a lot of thickness to play with. You may get away with 3mm but I don't think anything thicker would work without trimming the inner edge of the trims.
I doubt you'll find templates for that anywhere but with the trims removed then it's basically two rectangles on each side of the centre ribs. Here's a pic of mine with the trims removed when I installed some sound proofing:
I then finished it with 6mm foam and Veltrim carpet but both of these layers are compressible and the trim was a snug fit all around:
 Darren
Post #938895 22nd Jan 2022 10:13pm
Gal Dove
Thanks Darren. That's just the sort of thing that I've had in mind - very nice! But I'm not sure that I'd be brave enough to take to head lining down as well! Was it difficult?
I guess that it would be daft to not do the sound deadening at the same time - and most of the noise comes from the roof! Can I ask where you got the sound deadening and the black carpet trim from?
I might try to get some 2mm ply (if it's available that thin). Thumbs Up
What did you use to cover the wheel wells? Were you carpeting the whole area?
Post #938902 22nd Jan 2022 10:28pm
Taking the headlining down is mildly awkward but really not difficult. I think I've had at least the rear part out three times now and need to again for a project in the not too distant future.
All of the sound deadening material that I used came from eBay. The foil covered butyl is 2mm Silentcoat but the 6mm self-adhesive, closed cell foam is just something generic. The carpet is called Veltrim and is designed for vehicle use as it stretches to allow it to fit in and around awkward surfaces. There's some more details about what I've done here:
https://www.defender2.net/forum/post711655.html#711655
You can get very thin ply but I'd suggest that it won't be serve the purpose that you're looking for as the thin stuff really isn't very strong. Have a look at your side trims and see if you can measure how much tolerance you've got between the inner edge and the sides. You might get away with 4mm, which would probably do. You'd have to stick it in place with spray glue.
An alternative would be to remove the trims altogether and cover the whole sides with something thicker - 9 or 12mm perhaps. That would leave lot os space behind for insulation but would need some though to finish of the from and rear edges neatly. Darren
Post #938905 22nd Jan 2022 10:50pm
Gal Dove
Hi Darren. Many thanks, that's very helpful and I'll have a look at all the details that you've posted.
Thanks again!
Post #938925 23rd Jan 2022 1:30am
stew 46
England 2010 Defender 110 Puma 2.4 USW Bonatti Grey
You are better than a Haynes manual Darren 🤣👍 wish you lived a bit closer so I could pick you brains when needed Thumbs Up
Post #938937 23rd Jan 2022 8:53am
landy andy
Did mine with 15mm ply bonded in place and covered with eBay carpet.
Post #938940 23rd Jan 2022 9:13am
BrickBox
[/quote]
Hi Tony,
Where did you get the side nets from? They are a lovely size and the fit looks perfect.
Cheers Smile
Post #938944 23rd Jan 2022 9:44am
Gal Dove
Brickbox - looks like they come with the panels from Mud....
Post #938973 23rd Jan 2022 12:33pm
Gal Dove
Taking the headlining down...
...That would leave lot os space behind for insulation but would need some though to finish of the from and rear edges neatly.
That looks great Darren! I was just thinking that if I am going to be taking the headlining down then I would have the opportunity to instal a rear work light at the same time.
Did you DIY your own work light - and if so do you have any recommendations on wiring and switching (from the dashboard) and which would be the best light to go for (Lazer?). I'd also want to make the light un-nickable - so would be looking to secure form thew inside if that's possible?
I'd probably mainly use this light as a reversing light as I always struggle to see where I am whenever I reverse out of the drive!
Post #938977 23rd Jan 2022 12:52pm
One of my favourite subjects Very Happy There are lots of different ways of doing this, depending on what sort of functionality you want and how complicated you're willing for it to be. For example, I wanted my work lights to double as reversing lights but only when needed at night. I also wanted to limit the possibility of driving arond with them left on, as they're technically illegal to use on the road, anyway.
To that end, via a series of relays and connections to other circuits, mine come on when reverse is selected but only when the lights are on. They can also be independantly switched from the rear but will automatically turn off as soon as the brake pedal is pressed.
You can find the details of what I've done here:
https://www.defender2.net/forum/post717233.html#717233
https://www.defender2.net/forum/post717755.html#717755
As for lights, I initially went for some cheap eBay specials, that were pretty good for the money. More recently, I've replaced them with some 'scene' lights from Wilderness Lighting, which were more expensive but give an excellent spread of light:
https://www.defender2.net/forum/post911959.html#911959
They're all bolted through the panel and so are reasonably secure. Darren
Post #939009 23rd Jan 2022 3:42pm
