![]() | Home > Faults & Fixes (L663) > Gearbox Repair on Brand New Defender |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5115 ![]() ![]() ![]() |
I can recomend this mechanic for all gearbox related items.
![]() Click image to enlarge For those who like Welsh Mountains and narrow boats have a look at my videos and photos at.. http://www.youtube.com/user/conwy1 |
Muddybigdog Member Since: 11 Apr 2014 Location: Suffolk Posts: 1029 ![]() ![]() ![]() |
Did you have to wait long for parts? Jumped ship to reliability - Mitsubishi L200 Puma 90 XS - Sold D3 - 2.7 S x2 (both Sold) Freelander 2 HSE - Sold Freelander 1 - Sold Disco 2 - Sold |
Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 736 ![]() ![]() ![]() |
Probably water ingress
Nuclear Nick Member Since: 21 Aug 2021 Location: Southwest Posts: 291 ![]() ![]() |
No. It was an assembly fault due to an incompetent poorly trained and inexperienced worker. The fault was not found during assembly resulting in extensive disassembly to identify and rectify the fault. It turned out to be a gear wheel loose in the ‘box which could be returned to its rightful place with some difficulty due to tight access, so no new parts were required. The worker has been sent for further training.
What loner car did they offer you? Jumped ship to reliability - Mitsubishi L200
whiterdesign Member Since: 10 Jun 2021 Location: Preston Posts: 272 ![]() ![]() |
Probably this one
![]() Click image to enlarge 110 XS 250 MY 23 Gondwana Stone, Cold climate pack and towbar |
stng110 Member Since: 04 Jun 2021 Location: Melbourne Posts: 102 ![]() ![]() |
Well, mine has the same problem. Typical JLR subcontractor quality. But now my assembler is refusing to pull the car apart. Every time I mention it, he just bursts into tears. I’m not getting much sympathy from my significant other. I guess it’s just a garage queen, so who’d ares if it doesn’t work. Right? |
Nooooo, it needs to be purfect! I fixed mine with the help of some really good You Tube vids. Apparently the usual culprit is the CV joints in the two drive couplings to the gearbox and transfer box. It’s not made clear in the instructions but the joints need to be all aligned the same initially. In my case I think I dislodged the gear wheel when I was decoupling the drive shafts. All running silky smooth now.
Leeds Utd Member Since: 07 Jan 2022 Location: RP Posts: 119 ![]() ![]() |
Lets hope it brings as much fun as the real thing !
Smyles_ Member Since: 25 Aug 2018 Location: Copenhagen Posts: 518 ![]() ![]() |
Interestingly there was actually an error in the manual for the construction of the drive line in regards to u-joint alignment.
Stuart ![]() Cummins 130 Build Thread 58 130 Double Cab HCPU - Cairns Blue 04 110 Double Cab - Black (gone) 07 Audi RS4 Avant - Silver |
Yes, that was the problem I had. I found a similar video so I was able to sort it but the video you posted is much better in explaining the problem and the solution. While the instructions supplied with the kit are very good there are also some very good videos out there too. Probably some of those guys need to get out more!
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2297 ![]() ![]() ![]() |
Interesting... and thanks...
![]() Just about at that stage... so will align UJ's as suggested... ![]() Click image to enlarge Let's face it LEGO were trying to build a Model with Defender DNA... ![]() https://www.defender2.net/forum/topic83242.html |
Can I suggest, with the benefit of hindsight, that you fit the wheels somewhere around stage 365, before fitting seats and bodywork, and try out the transmission in all its modes? This might avoid having to do a lot of dismantling to get back into the drive train to sort out any issues.
But then you may already be planning to do this....... ![]() |
