- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
![](templates/vbnew/images/breadcrumblogo.gif) |
Home > Td5 > TD5 strange starting issue |
lightning
![](templates/vbnew/images/spacer.gif)
landy andy wrote:I would change the starter. I’m assuming that you changed the fuel pressure regulator due to it leaking, and if it was leaking they drip onto your starter motor. A dodgy starter motor can give a strange electrical spike to the ecu causing issues.
l had the exact same thing, changed various things and eventually traced it to the starter motor.
A TD5 should still start instantly from cold in temperature around freezing without working glow plugs.
21st Jan 2022 11:06pm |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
