Home > Td5 > Ignition Live
cocker
Ignition Live
Hi everyone need your help can anyone point me in the direction of an ignition feed in the engine bay of a 2005 TD5
Thanks
Peter
Post #938569 20th Jan 2022 7:23pm
geobloke
There isn't much choice in the engine bay, but there is behind the dash and a wire can easily be taken from the IGN and pushed through the bulkhead grommet the power whatever you need to.
What are you wanting to power off the IGN feed? If something that requires a lot of current you will have to fit a relay.
EDIT: There is an IGN live on the back of the alternator that you would have to splice in to, but it is in the engine bay.
Post #938573 20th Jan 2022 7:44pm
landy andy
As said. You are far better, and it’s easier to get the required power from behind the dash binnacle and there is also room to get it through the bulkhead grommet.
Post #938583 20th Jan 2022 8:34pm
jimbo55
There’s an ignition live in the engine bay, by the heater box there’s a multiplug, can’t remember the colour but is definitely there
It’s where I took the feed for my drl’s from
Post #938584 20th Jan 2022 8:36pm
geobloke
Good call Jimbo. Useful to know Thumbs Up
Post #938594 20th Jan 2022 8:59pm
cocker
by the heater box sounds good its for DRL'S
Thanks
Post #938595 20th Jan 2022 9:05pm
jimbo55
Image is just from google, but to the right of the heater matrix there’s a large grey connector which is where I took the ignition feed
Post #938599 20th Jan 2022 9:24pm
