Home > Td5 > Sealing a Td5 safari snorkel to the airbox. |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5787 |
If you want the best chance to keep water out of your air intake system then fit a nugget stuff air intake (depending on which snork you have). Otherwise you have many joints and valves in the system.
Snork to wing, air intake to wing, air intake to solid pipe, solids pipe to flex pipe, flex pipe to water drain valve, water drain valve to flex pipe, flex pipe to air filter housing, and then two holes inside air filter housing. All these need to be sealed and air tight. https://www.4x4overlander.com/product/nugg...ox-300tdi/ Last edited by landy andy on 14th Jan 2022 11:28am. Edited 2 times in total |
14th Jan 2022 11:19am |
Click image to enlarge |
14th Jan 2022 11:20am |
