![]() | Home > General & Technical (L663) > Defender diesel used for short journeys |
Tim in Scotland Member Since: 23 May 2007 Location: The Land that time forgot Posts: 3753 ![]() ![]() |
Oil dilution with L663 Defender doesn’t seem to be a problem - I suspect be at because the engine/DPF layout has been done from a clean sheet design unlike the older engined cars where the DPF had to be squeezed into an existing un bonnet layout as best as they could. Mine also isn’t using very much AdBlu
It was last topped up in June 2021 at 11000’ish miles, now at 15300 miles nd it will take 1.6 gallons to fill it again or I have 3160 miles of AdBlu range. Mine is the now obsolete 2.0 D240. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come 2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
