Home > Maintenance & Modifications > D44 SPECTRE BUMPER & GENUINE A BAR
Trendkill110
United Kingdom 2008 Defender 110 Puma 2.4 XS DCPU Barolo Black
Hello.
My D44 Spectre bumper has just arrived and I've collected a Genuine Defender Soft A bar this afternoon.
Does anyone know if I'm supposed to be cutting the part that's not letting it sit back and flush to the bumper? See photo.
TIA 👍🏻
Post #937128 10th Jan 2022 9:15pm
Roy5695
I had to trip the inside edges of my A bar when I fitted it to a spectre bumper.
If you look at the back of the A bar, mine had “mould” marks where the cuts needed to be. Almost pre-formed areas that needed to be removed.
If you look from the from currently it may look splayed out at the bottom? 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #937129 10th Jan 2022 9:21pm
Ianh
I think the A-bar you have is for a std straight bumper - VPLPP0060, you need a different one for a winch or d44 spectre bumper - VPLPP0061 https://www.devon4x4.com/vplpp0061-protection-bar-408014.html
Post #937158 11th Jan 2022 12:18am
mcma1
If its a genuine A bar you will see the tooling marks to cut to for a winch bumper as Roy pointed out Andy
2014 Fuji 110 SW LS3
https://www.defender2.net/forum/post751233.html#751233
2014 Corris 110 SW
http://www.defender2.net/forum/topic40056.html
My old Xtech 90 build..
http://www.defender2.net/forum/topic15681.html
LS3 V8 build...
http://www.defender2.net/forum/topic49051.html
Post #937163 11th Jan 2022 7:44am
Trendkill110
Pretty sure it's genuine 👍🏻
Post #937181 11th Jan 2022 10:08am
Roy5695
This line here. Trim this bit out abs it should fit flush 🤙
Instagram - @r22oyp
Roy
Post #937270 11th Jan 2022 10:33pm
Fiebre
Spain 2008 Defender 90 Puma 2.4 SW Java Black
Hello,
There is somewhere a tutorial to transform a VPLPP0060 in a VPLPP0061? I want to buy a winch and I have the soft A bar not ready for it.
Have anybody mount the winchmax with the winch bumper in a SVX front grille?
Thanks for your feedbacks.
Regards,
Post #998289 2nd Jul 2023 5:01pm
