Home > Puma (Tdci) > Rear half shaft updates - what's this guy hiding in the hub |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5610 |
Middle is half shaft, then the stub axle, then the stake nut that holds the bearing in place.
9th Jan 2022 11:24pm |
This may explain better.
Click image to enlarge Your assembly looks like it may have rust in and need striping down. But I can’t see any damage just the staking, of the stake nut. (This is where you smack part of the nut flat against the flat bit below to lock it into position, to stop it undoing on its own.) Last edited by landy andy on 9th Jan 2022 11:30pm. Edited 1 time in total |
9th Jan 2022 11:27pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2400 |
nut pn is RFD100000 Puma 110" SW
9th Jan 2022 11:28pm |
lemons Member Since: 13 Jul 2021 Location: London Posts: 20 |
Ah ok that was dumb of me - makes a lot of sense, I couldn't work out how that could have got damaged
Thanks for the help! |
9th Jan 2022 11:38pm |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6290 |
perhaps theres something I can't see but if you're referring to the 'dent' I believe thats intentional - a form of lock nut to prevent it coming loose.
sorry if I'm telling you what you already know. good luck with getting it sorted. oops sorry. just noticed the responses above. I hadn't done a refresh since last night. |
10th Jan 2022 8:57am |
