Home > Puma (Tdci) > Rear half shaft updates - what's this guy hiding in the hub
lemons
United Kingdom 2010 Defender 90 Puma 2.4 HT Santorini Black
Hello!
Just in the process of updating my rear drive shafts after it annoyingly popped out my hub centre cap on the motorway 🙄 and noticed some damage to the hub nuts when taking it apart
Does anyone know the part number of the brass part inside that? I can seem to work out what it is, but as it's damaged may be worth replacing at the same time (no idea how these got knocked!)
Any help much appreciated!
Post #937002 9th Jan 2022 11:12pm
landy andy
Middle is half shaft, then the stub axle, then the stake nut that holds the bearing in place.
Post #937006 9th Jan 2022 11:24pm
landy andy
This may explain better.
Your assembly looks like it may have rust in and need striping down.
But I can’t see any damage just the staking, of the stake nut. (This is where you smack part of the nut flat against the flat bit below to lock it into position, to stop it undoing on its own.)
Post #937007 9th Jan 2022 11:27pm
MK
nut pn is RFD100000 Puma 110" SW
Post #937008 9th Jan 2022 11:28pm
lemons
Ah ok that was dumb of me - makes a lot of sense, I couldn't work out how that could have got damaged
Thanks for the help!
Post #937010 9th Jan 2022 11:38pm
Caterham
perhaps theres something I can't see but if you're referring to the 'dent' I believe thats intentional - a form of lock nut to prevent it coming loose.
sorry if I'm telling you what you already know.
good luck with getting it sorted. Thumbs Up
oops sorry. just noticed the responses above. I hadn't done a refresh since last night.
Post #937021 10th Jan 2022 8:57am
