![]() | Home > Puma (Tdci) > Heated seat switches |
Race.it Member Since: 27 Aug 2019 Location: Algeciras Posts: 831 ![]() ![]() ![]() |
So Santa and the three wise men (Spanish thing) brought my 110 some gifts for heated seats, somebody forgot to put in switches and I have managed to find out at present they are not at present avaliable from LR. Most places even if they say are in stock soon return my money and an apology they they are not in stock and no eta.
It’s not just the seat switches they look to be out of stock, quite a few of the others also. Anybody think they will be ever back in stock or do I need to start to think of a cunning plan, fitting a toggle switch instead etc. I know covid is screwing supply chains all over but as you lot have been around on here longer than me has this issue occurred in the past or is this a new one? Searching for my first Defender...and started just as Covid hit, so talk about timing. 5 months after starting the search I found it, and here is the details |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3701 ![]() ![]() ![]() |
Could you look at breakers/scrap yards?
Breakers here are not that good Searching for my first Defender...and started just as Covid hit, so talk about timing.
Thought that may be the case. Rimmer have them showing as stock. Not cheap though!:
https://rimmerbros.com/Item--i-YUG102430--...gLkg_D_BwE |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17626 ![]() ![]() ![]() |
^^ That's a Td5 or Disco 2 heated seat switch, not a Puma. Puma is YUF500150LNF.
I don't know if the MG/Rover switch YUG101870PMP could be used, it is at least the correct orientation and cheap. Exmoor Trim and Defender Upgrades do not say that they are out of stock, although it is of course possible that they are. |
Exmoor trim won’t let me add to cart so assuming they are out. And I have tried twice to buy from defender upgrades and failed both times.
Thanks for looking though. According to the people I have spoken to (even ordered from) lr is out of stock and no date for restocking. Searching for my first Defender...and started just as Covid hit, so talk about timing. 5 months after starting the search I found it, and here is the details |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20652 ![]() ![]() |
Maybe worth asking about stock before buying but try:
https://www.devon4x4.com/yuf500150lnf-switch-431465.html https://www.paddockspares.com/yuf500150lnf-switch-assy.html TheThunder Rolls🇬🇧🇺🇸 ⛽️🛢️⚙️🧰💪 |
Thanks the paddock spares gets them from lr hence the 2-3 days but I know Landrover has non.
Waiting on Devon4x4 to get back to me, thanks Searching for my first Defender...and started just as Covid hit, so talk about timing. 5 months after starting the search I found it, and here is the details |
Good luck.
Ok we have success at present from Garath at defender upgrades. He has some non Landrover heated switches that are the same as oem.
Only trouble is it’s cost me a few other items when buying 😂 Searching for my first Defender...and started just as Covid hit, so talk about timing. 5 months after starting the search I found it, and here is the details |
Gareth always comes up with the goods!
