Home > In Car Electronics > Quick aux power question
pilsburypie
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Corris Grey
I’ve read the post about installing a rear power socket…. Mine relates to the front.
I’ve bought a little double usb socket I want to install inside my cubby box. Clearly the battery is very close in the seat box next to it. Can I simply wire this socket straight to battery negative and positive with a fuse in line? Would like constant power even when ignition off.
If not, what should I do?
Post #936285 4th Jan 2022 12:07pm
Mo Murphy
Yes.
50 Shades of Pennine Grey
Post #936296 4th Jan 2022 12:45pm
gilarion
Yes, but for safety place an in-line fuse in the positive wire as you have mentioned. Either a five or ten amp fast blow. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #936300 4th Jan 2022 1:19pm
pilsburypie
Cheers peeps.
Post #936323 4th Jan 2022 5:15pm
Jeff 8
Australia 1998 Defender 110 300 Tdi SW Chawton White
I have always wired USB sockets through a switch, as I believe they are a constant but small drain.
Jeff
Post #936897 8th Jan 2022 11:33pm
As Gilarion said but fuse as close to battery live as practical.
It won’t cause any battery drain as long as it doesn’t have any lighting such as an LED indicator or similar lighting.
If it does then it won’t be any good. (Unless switched).
Blue sea do some good sockets. TheThunderRolls🇬🇧🇺🇸
Post #936898 8th Jan 2022 11:48pm
