Home > Td5 > Headlamps fault |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 937 |
Suggest that it is most likely your light switch in the column that is failing. If you don’t have a Boomslang style relayed wiring loom between the switch and lights it burns our the switch. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
3rd Jan 2022 10:24pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5724 |
If it was the switch I’d think it would make both headlamps have the same problem. I think I’d start by checking fuses.
4th Jan 2022 8:37am |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2237 |
Cant really get my head around how this fault can occur (unless the original wiring has been modified).
It is a common cable for both lights through the stalks and right upto the fuseboard where it splits for right and left bulbs. There is no difference/discrimination in the wiring for whether normal full-beam or dipped beam is selected. The only difference is on the supply to the stalk where a different fuse feeds the 'flash' position but if it was a fault on the supply fuse, the other full beam lamp or dipped beam would not function either. Has the wiring been messed with at all? Steve 02' 110 TD5 Double Cab Rebuild Thread |
4th Jan 2022 9:59am |
Another thing that is different is that when on main beam the dipped is off, but in flash you get main, and dipped power. Is this what you are getting at bulb?
Really odd not having the warning dash light. Have you tried swapping relay? |
4th Jan 2022 10:53am |
mpald Member Since: 16 Dec 2016 Location: North East Posts: 46 |
Thank you for the suggestions; the relay was fine and it seems it was a dubious fuse, and all is fine for the moment.
5th Jan 2022 8:37pm |
