![]() | Home > Td5 > Rear propshaft to T/C box bolts |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17705 ![]() ![]() ![]() |
The flange has to come off, but this is relatively little extra hassle by the time you get there. It is possible that the wrong size bolts have been used in the past and the head of the bolt is not restrained as it should be, resulting in the bolt spinning.
To remove it, due to the difficulty with access, my likely approach would be to drill through at least one and probably two opposite flats of the nut then split the nut with a chisel. Grinding or sawing is likely to be difficult due to the propshaft. Then correctly assembled the bolts (which as I recall are 3/8" UNF) have their heads constrained from rotation by a machined edge on the back of the flange, and are loosely held in place by a large circlip. |
Lionel Member Since: 12 Aug 2008 Location: Melbourne Posts: 59 ![]() ![]() |
Thanks blackwolf for your advice.
It's not good news though, to have to remove the flange. I will need to get some sort of retaining/holding tool to remove the flange nut, which can be very tight, & of course, it would be silly not to replace the seal, & possible the flange as well. I'm hoping I can get the nut off without grinding or drilling though - there is enough slack to get a large screw driver between the nut & the flange to apply leverage & maybe (?) wind it off. I have a feeling that it is the nut that has failed, rather than the bolt. It would still be a miracle if the existing bolt (original) is not chewed during the process, even if all goes well. Anyway, I'll give it a go, & see where we end up. At least a flange kit is not too expensive. Cheers, Lionel |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3530 ![]() ![]() ![]() |
If you have enough slack, maybe you can put a hacksaw between the prop flange and the brake drum?
If the nut is spinning, most likely with a new lock nut, the bolt would spin again. If you hack the old bolt out, probably you can remove the old sawn bolt without taking the flange off, but need to shift the circlip that retains the bolts. If you really do not fancy taking the flange out, you could use a ‘stud, and put a nut behind the flange, perhaps nut glued so that it will not spin. Not really a proper fix, as the bolts should have a solid stem, but could work until you take the flange out next time. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
You might be lucky with this approach, but it is made much harder by the fact that you can't get the handbrake drum off with the propshaft in place.
Holding the flange whilst undoing (or doing up) the flange nut isn't difficult, if you don't have a holding tool (something like this) simply use a bar between two of the propshaft bolts. As long as you are careful you won't damage them. |
Thanks for your input. However I should clarify my problem, as the bolt is not spinning, it is just that the propshaft nut can be turned with a spanner, but not progress along the bolt thread in order to remove it. I have yet to try exerting pressure behind the nut & turning it with the ring spanner, & I am hopeful that it may be able to be wound off without having to drill or grind the nut. I'll try that today, hopefully, & then update. Cheers, Lionel |
Thanks blackwolf. I'll do a bit more on it today & see how I get on. Cheers, Lionel |
I just thought I should complete this thread.
The job was a doddle really. I was able to use a hacksaw to cut through the damaged bolt, which i could not undo in the normal fashion. No problem then to remove the rear propshaft. The rest of it was quite routine. I found that I coulld easily undo the flange (M20) bolt by pulling the handbrake fully on - this was more than enough to allow my Milwaukee impact driver to undo the nut, which was VERY tight. Then I could remove the handbrake drum after winding off the 17mm adjuster for the handbrake. I had a puller handy to remove the flange, but this was not necessary as it came off easily by hand ( I nearly dropped the thing!). Changing the seal was quite routine - I used a 52mm impact socket as a drift to drive in the new one. Then I just re-assembled everything else using new bolts & M20 nyloc nut for the flange, torquing everything to specs.. I even remembered to put new oil in the T/F box (!!). All appears good, with no nasty vibes or oil leaks. Thanks to all for the helpful input. Cheers, Lionel |
Excellent and thanks for updating the thread.
