Home > Maintenance & Modifications > Defender 90 TD5 Safari snorkle - underbonnet hose routing |
Marlin.45 Member Since: 20 May 2014 Location: Llangadog, Carmarthenshire Posts: 54 |
A few months ago the RH wing was removed to help with a new ABS modulator install. Since then the snorkle pipework has been rubbing on the steering column shaft. They had one attempt to fix this and its a bit of a bodge and I would prefer to fix it properly?
Would anyone have some pics of their under bonnet hose routing so I can check where someone has prob fubar'd? Failing this I will run a single hose from the wing pass thro and onto the air filter. TY 2006 TD5 90 County 1961 MF35 |
3rd Jan 2022 2:51pm |
https://www.lrworkshop.com/diagrams/land-r...er_53455#7
I think I can see where the problem is now.
2. Item 7 has a hole worn thro due to the steering column linkage rubbing. Replace with a 30 deg. kink silicone tube. 3. Item 9 no longer has a bracket. Been snapped off at some point so that is free floating. I will do a quick search and see whether anyone can supply a complete silicone kit to replace all the intake hoses from the wing to the airbox. There must be? 2006 TD5 90 County 1961 MF35 Last edited by Marlin.45 on 3rd Jan 2022 5:40pm. Edited 1 time in total |
3rd Jan 2022 4:57pm |
Unfortunately this Safari snorkel has an alternative 'item 1'. I will do a search for 'Sealed Nugget'. TY for that. 2006 TD5 90 County
1961 MF35 |
3rd Jan 2022 5:43pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5733 |
It won’t work with yours then.
Here. https://www.4x4overlander.com/product/nugg...ox-300tdi/ |
3rd Jan 2022 5:44pm |
Cheers Andy,
You're right. It won't Back to the Google hunt or rig it DIY 2006 TD5 90 County 1961 MF35 |
3rd Jan 2022 5:56pm |
Click image to enlarge Hopefully most of the ordered parts will arrive here tomorrow but in the meantime I have been looking at the air filter box. I want to remove and clean thoroughly (full of rusty lumps from that corroded intake pipe). Airbox now out and after removing the inlet pipe to the cyclone....3x bluetits ! Well if the cyclone restricts the flow then these surely add to it? Rodding through the RAI now to check for nests....or remains of So cyclone removal - yay or nej ? 2006 TD5 90 County 1961 MF35 |
4th Jan 2022 6:49pm |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6306 |
4th Jan 2022 8:08pm |
WOW. Looks like that cyclone saved you this time. I assume your thinking they went in via the rated tube, not in via the snork air intake.
4th Jan 2022 8:14pm |
I am guess they went in thro the RAI at some point in the past to make a nest. Checked the snorkel and nothing else found. Could have been in there for years as I have never taken it apart before (we have had the 90 for 10 years).
Hiclone/Cyclone now removed anyway so a clear 2.5" path right it to the filter 2006 TD5 90 County 1961 MF35 |
4th Jan 2022 9:49pm |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2644 |
You could still remove the cyclone as the feathers won’t pass through the air filter.
If anything it would cause less of a restriction than blocking a small area. |
5th Jan 2022 8:03am |
Looking at the desiccated baby bluetit bodies lying on the gravel this morning it wasn't 3...it was 5. Party in the airbox?
Cyclone now removed o/ Hopefully the parts I have ordered to replace the original ductwork up to the airbox will arrive tomorrow. 2006 TD5 90 County 1961 MF35 |
5th Jan 2022 10:43pm |
Looking at the routing again now the parts have arrived this still does not look straightforward.
The outlet rubber hose from the Safari RAI assy points directly at the steering column linkage. To force that in a line below the linkage will take some effort (steel tube and bracketry mounted to the original water dump valve position?). Not keen on that amount of force being applied so I am looking at alternatives. I do not really need the RAI. We do not wade and no longer life in a dusty environment in the summer months. An air supply from the top of the wing would be more than enough. Removal if the Safari RAI would need to be a later project as that looks like a PITA to get off the wing due to nut access on the inside. 2006 TD5 90 County 1961 MF35 |
6th Jan 2022 11:52am |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2237 |
Have you got some photos of the parts you have got? The steel tube doesnt seem to be part of the original setup.
From what I recall the original Safari snorkel for TD5s (which I have fitted) which was also for 300tdi had a rubber hose which fitted directly onto a pipe stub which is part of the snorkel. The later version for TD5s with ABS and TDCi uses the original land rover intake moulding on the inside of the wing. Sounds like you have the earlier one which will probably be tight with the ABS block. 02' 110 TD5 Double Cab Rebuild Thread |
6th Jan 2022 1:38pm |
Pics of a standard Td5 incase it help.
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge |
6th Jan 2022 1:48pm |
