![]() | Home > In Car Electronics > Double din surround to fit better - how |
twdi Member Since: 18 Nov 2021 Location: Eindhoven Posts: 7 ![]() ![]() |
Yes you are right.
Unfortunately the 2-din fascia's are still expensive and I want to have it installed by a professional. SO I guess, I have to accept the higher price although a 1din flip-screen like Alpine's Halo9 is way more expensive then let's say a Kenwood DMX7018 |
Beeder Member Since: 19 Nov 2017 Location: Nuneaton Posts: 17 ![]() ![]() |
I’ve had my DD installed a couple of years with the pioneer F88. I’ve done everything to try make it fit flush, even heated the plastic heater pipe deforming it backwards. Nothing I have tried works
I’ve given up. It’s a lost cause until I replace the unit |
andy2111 Member Since: 17 Oct 2021 Location: Kent Posts: 368 ![]() ![]() ![]() |
Hi Matty, you mentioned you managed to replace one of the missing fascia panel spring clips - do you have the part number or a link you can share as I need to get a couple - many thanks |
