![]() | Home > Technical > TD5 turns over but won;t fire |
htb2 Member Since: 02 Nov 2018 Location: Carmarthenshire Posts: 547 ![]() ![]() |
Can you hear the fuel pump running?
Clive Member Since: 21 Mar 2014 Location: Littleborough Posts: 467 ![]() ![]() ![]() |
I had a similar problem with mine a while ago, it would usually start eventually though.
In my case it was caused by a faulty starter motor, (not sure if it was worn motor brushes of shorted turns in the armature,) anyway whatever it was, it was causing loads of electrical interference right next to the crank sensor and swamping the signal to the ECU, shows up on a code reader as "noisy crank signal". A new starter motor cured it immediately. An easy way to check is by bump-starting it, that way it never failed and always started immediately. |
