Home > Td5 > Windscreen washer jet replacement not working
G-P
United Kingdom 2006 Defender 90 Td5 CSW Zermatt Silver
So I decided to finally replace the pathetic windscreen washer jet, the main delay in doing this was I thought given the location it would be a real pain to do and I was not disappointed!
However before I put the dash all back together I checked to make sure it worked and it’s even worse! It just dribbles out the end! I have checked for leaks and can not find any, have I missed something really obvious!
It’s a non genuine part, but one with some great reviews.
Thanks in advance
Graham
Post #927403 27th Oct 2021 8:17pm
htb2
Wales
What's the flow like without the jet attached?
That will tell you where the problem is.
Post #927404 27th Oct 2021 8:21pm
landy andy
There is a one way valve that can get Censored in it and restrict flow.
Post #927410 27th Oct 2021 8:41pm
jeffersj
United Kingdom 1996 Defender 90 300 Tdi HT Bronze Green
Also check the connectors at the washer bottle end as they can need cleaning up. While i had my dash off i took the nozzle from the centre hole and added another nozzle utilising the 2 blanked hols for LHD vehicles. Divided the pipe evenly and both nozzles work OK off the one pump. Jeff
Ex 1968 Series 2A
Ex 90 TD5
Ex D3
Ex D4
Post #927509 28th Oct 2021 9:26am
markb110
Happened to me a few years back……little beggar..
Post #927510 28th Oct 2021 9:32am
roel
I took mine out. Now I have less problems with frozen nozzles but the first time it takes a while before getting water on the screen. Now the dirt is all over the window before there is water to wash it off. Roel
2003 90 Td5 (2009-now)
Post #927568 28th Oct 2021 2:18pm
Leathers
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Galway Green
Re: Windscreen washer jet replacement not working
Do you mind me asking what the outcome was? Just fitted a CSI parts washer jet and have the same snag - lack of ‘oomph’ so I’ve ordered their pump.
Post #935706 31st Dec 2021 12:14am
Guinness
when i purchased my TD5, the previous owner had managed to pinch the flexible pipe when refitting the dash restricting the washer flow
Post #935708 31st Dec 2021 12:21am
Mossberg
United Kingdom 1993 Defender 90 300 Tdi HT Aintree Green
I just changed the washer jet on my defender. The part is in two pieces so potentially you may not have to do the fiddley bit behind the dash as the section with the jets can be taken off the threaded section. It is a bit awkward to do as you feel you might brake it when doing it.
I separated them using a tiny crow bar. On the truck I used a thin piece of wood to protect the truck paintwork. I just applied gradually increasing pressure until it separated. To separate the new unit I drilled a suitable size hole in a piece of angle, fitted the full unit into said hole, then applied pressure as before.
Then test for water flow on the truck before fitting the new piece to the existing part that passes through the vehicle skin.
This may be a bit late for you if you have already changed yours, but it may help others doing the same task.
I hope you get it sorted.
Mick
Post #935717 31st Dec 2021 6:59am
Laughing You know there’s a little access panel, behind the stereo?
It’s a 10 minute job, remove the ashtray to add light.
Post #935718 31st Dec 2021 7:06am
Mossberg
Ah, no I didn't know that and thanks for sharing. I would not have been as worried if I had known that! However replacement of the jet part worked for me so all good 👍
Post #935720 31st Dec 2021 7:11am
Fab, if people use the search facility in the future, they’ll see and hopefully it’ll help them.
The access panel (held in with 4 screws) also has a little ‘half moon’ cut out at the top, so if you’re upgrading to a DAB radio you can route the antenna and mic cable through there, to save drilling holes.
Post #935721 31st Dec 2021 7:16am
Mossberg
I must admit, as someone with little knowledge and experience on the truck (well any automotive repair) I tend to be reluctant to try things as I am worried I am going to brake it! I really need to get more confidence 😩
Give me the angle grinder and welder any time!!!
Post #935722 31st Dec 2021 7:23am
