Home > Maintenance & Modifications > Optimill QR boss cover
Page 2 of 2 <12
landy andy
Only place that had stock was mud stuff and not the best price. But a stolen Defender less than 7 miles away from me meant cost wasn’t the priority.
It’s not an excellent design, and clearly I’m not the only one struggling with it. It needs to lock as one part when the lock barrel is out, and then spin as two parts when barrel in and in locked position. I don’t understand this poke your finger between the parts bits as I have man hands, and they can’t fit in the tiny gap. At this rate I will try the shove something between the two bits or even a glop of silicone between the two bits so to weakly join the two bits.
Post #935067 25th Dec 2021 10:37pm
You don't have to poke anything in a tiny gap. Just put your finger on one of the holes and use that as a guide to line up with the pins. Darren
Post #935071 25th Dec 2021 11:09pm
JPE
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Firenze Red
Don't over think it, just put a finger over a hole to help your brain line it up with the pin you are aiming for.
Post #935077 26th Dec 2021 12:11am
landy andy
Will try again once home. Only used it three times so far.
Post #935084 26th Dec 2021 8:10am
MichaelE
All you people who keep saying "Just poke your finger in between.......easy" etc are failing to understand that not all men have delicate ladies fingers slim enough to do so, so it's pointless to keep repeating it as if there is something wrong with us failures and we must be mutants. A good number of us have Land Rover fingers and they just do not do it.
It's obviously a problem that Optimill are aware of else they wouldn't have given me their solution that I posted earlier. At the time we discussed my idea of some sort of protruding tab attached to the inner part with which to rotate it. I wouldn't be surprised to see a Mk2 version at some point.
Post #935146 26th Dec 2021 1:29pm
If it's giving you problems, you could make a finger-size hole through the outer skirt so you can hold the inner part while locating it on the pegs.
Post #935147 26th Dec 2021 1:34pm
discomog
I think we are already on the Mk2 version, didn't they change the lock from the original spec? Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #935148 26th Dec 2021 1:36pm
JPE
Never been described as having ladies fingers before!
Not quite the reaction I’d expected when trying to help.
Clearly some misunderstanding though, you don’t need to put a tiny finger in the hole, you just feel where it is.
Hope you find a solution that works for you.
Post #935199 26th Dec 2021 8:24pm
Yes, the lock was changed to improve resistance to drilling and impressioning attacks. Only the lock itself was changed.
Post #935205 26th Dec 2021 8:50pm
donmacn
Seconded. (Thanks JPE). Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #935216 26th Dec 2021 10:33pm
90 Dreamer
A small relief in the underside of the swivel to indicate pin position......
Post #935268 27th Dec 2021 11:40am
Tegner
United Kingdom 2010 Defender 90 Puma 2.4 HT Zermatt Silver
small piece of tape on the outer cover - line the top hole with the tape and slip over the the top peg holding the inner - takes seconds
Post #935282 27th Dec 2021 1:14pm
Page 2 of 2 <12
