Home > Maintenance & Modifications > Optimill QR boss cover |
You don't have to poke anything in a tiny gap. Just put your finger on one of the holes and use that as a guide to line up with the pins. Darren
25th Dec 2021 11:09pm |
JPE Member Since: 19 Nov 2018 Location: South West England Posts: 333 |
Don't over think it, just put a finger over a hole to help your brain line it up with the pin you are aiming for.
26th Dec 2021 12:11am |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5666 |
Will try again once home. Only used it three times so far.
26th Dec 2021 8:10am |
MichaelE Member Since: 18 Jan 2020 Location: Crawley West Sussex Posts: 155 |
All you people who keep saying "Just poke your finger in between.......easy" etc are failing to understand that not all men have delicate ladies fingers slim enough to do so, so it's pointless to keep repeating it as if there is something wrong with us failures and we must be mutants. A good number of us have Land Rover fingers and they just do not do it.
It's obviously a problem that Optimill are aware of else they wouldn't have given me their solution that I posted earlier. At the time we discussed my idea of some sort of protruding tab attached to the inner part with which to rotate it. I wouldn't be surprised to see a Mk2 version at some point. |
26th Dec 2021 1:29pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17351 |
If it's giving you problems, you could make a finger-size hole through the outer skirt so you can hold the inner part while locating it on the pegs.
26th Dec 2021 1:34pm |
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2526 |
I think we are already on the Mk2 version, didn't they change the lock from the original spec? Defender 90XS SW
26th Dec 2021 1:36pm |
Never been described as having ladies fingers before!
Not quite the reaction I’d expected when trying to help. Clearly some misunderstanding though, you don’t need to put a tiny finger in the hole, you just feel where it is. Hope you find a solution that works for you. |
26th Dec 2021 8:24pm |
Yes, the lock was changed to improve resistance to drilling and impressioning attacks. Only the lock itself was changed. |
26th Dec 2021 8:50pm |
donmacn Member Since: 06 Nov 2017 Location: Nth Scotland Posts: 1841 |
Seconded. (Thanks JPE). Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
26th Dec 2021 10:33pm |
90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2141 |
A small relief in the underside of the swivel to indicate pin position......
27th Dec 2021 11:40am |
Tegner Member Since: 31 Jul 2018 Location: Alnwick Northumberland Posts: 183 |
small piece of tape on the outer cover - line the top hole with the tape and slip over the the top peg holding the inner - takes seconds
27th Dec 2021 1:14pm |
