![]() | Home > Maintenance & Modifications > Oil pump bolt |
After five years I have had no problem with the thread lock on the replacement pump bolt and yes I did check.
![]() Buy a new bolt and go with that. Never heard of a problem with the new LR thread locked bolts... |
taffrican Member Since: 14 Jan 2011 Location: Living room Posts: 625 ![]() ![]() ![]() |
Thanks for the tip, I just put the new one in, the old one was still tight, it looked like it had maybe one or two threads of loctite on but at least now I can rest easy, just praying the sump gasket doesn’t leak.
![]() Pessimists say the glass is half empty.. Engineers say the glass is twice the size it needs to be! |
Excellent.
