![]() | Home > In Car Electronics > Headlights go out....! |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2238 ![]() ![]() ![]() |
Sounds like a classic symptom of the headlight switch dying. Get it swapped over asap.
Cheers, Steve 02' 110 TD5 Double Cab Rebuild Thread |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2326 ![]() ![]() ![]() |
I concur, dead headlamp switch, as the whole headlamp power goes through it, eventually melting the plastic that holds the contacts inside. Avoid this happening again by making or buying an additional lighting harness with relays.
phillips321 Member Since: 16 Dec 2021 Location: UK Posts: 103 ![]() ![]() |
As in all of the amps that go through the light are drawn through this switch and there's no relays???? That can't be right can it?
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2732 ![]() ![]() |
It’s exactly right. There are relays in the system but they’re to do with ignition switching and dim/dip. The lamp current goes through the switch.
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20754 ![]() ![]() |
Replace switch then fit this is your solution:
https://shop.landreiziger.nl/lichtversterk...elaar.html (View in Google chrome and you can use auto language translate). Alternatively, if you are able to and skilled enough you can make your own. WeWillWin🇬🇧🇺🇸 ⛽️🛢️⚙️🧰💪 |
So switched changed and still have the same fault, any idea where the relay R123 is located in the vehicle (shown mid left of the below image) .
![]() Click image to enlarge Many thanks |
passengers fuse box C0282
had same problem with 03 reg 90 with relay holder burnt and the blue wires burnt too ended up making two repair tells new female blade terminal ![]() Click image to enlarge |
Penfold_6290 Member Since: 22 Sep 2021 Location: Dorset Posts: 341 ![]() ![]() ![]() |
The relay you refer to (C0282) is in the passenger compartment fuse box. There is also a pink relay, the dim-dip relay, located behind the instrument pack. This went wrong on mine recently but that only affected dipped beam, not full beam as well.
MM |
Dave T Member Since: 07 Jun 2013 Location: Glasgow Posts: 490 ![]() ![]() ![]() |
I would do the wiring mod anyway before the switch does go, the loom is also available at Paddocks https://www.paddockspares.com/boomslang-pe...-loom.html 2015 RRS Autobiography SDV6
1994 Def 90 300tdi |
