Home > Puma (Tdci) > Webasto in Puma
Chris Rogers
2013 Defender 110 Puma 2.2 USW Bonatti Grey
Webasto in Puma
Hi Guys,
I've just taken delivery of my fantastic new XS utility and am interested in fitting a webasto heater to it as I've already got on sitting in the garage.
Anyone found a good mounting solution? I'm a bit shocked at how little space there is under the bonnet!
Post #89985 19th Sep 2011 2:03pm
BigMike
There are loads of thread on this if you do a search
Post #89987 19th Sep 2011 2:24pm
dgardel
Italy
Look here
http://www.defender2.net/forum/post49777.html#49777 Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #89990 19th Sep 2011 2:31pm
cobs
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Cairns Blue
Am in process of mounting mine under front wing, driver's side just behind headlight. Will post some pics when I get a bit further
Post #90457 21st Sep 2011 6:33pm
Chris Rogers
fantastic - I'd love to see how you've done it.
I know there have been a few posts, but mainly seem to be from LHD users!
Post #90504 21st Sep 2011 9:14pm
thebigblue
Denmark
Any progress Question
Post #93280 8th Oct 2011 1:37pm
XS Pete
England 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Cobs has posted some more information here:
http://www.defender2.net/forum/topic8509.html
Including links to some very detailed documentation he's written including pictures about the whole process.
Pete
Post #93291 8th Oct 2011 3:03pm
thebigblue
Denmark
thx
Post #93301 8th Oct 2011 4:53pm
cobs
pic of the Thermo Top C during fitting
Post #93400 9th Oct 2011 1:49pm
T1G UP
looks like a smart place.....same as D3?
Post #93416 9th Oct 2011 3:20pm
thebigblue
Denmark
Cobs - I read your extensive installation write-up.
Thanks for sharing, and taking the effort to do it.
I understand it took a little while for the unit to power up, caused by lack of diesel flow. I would suggest to others that you prior to the final connecting of the fuel pipe to the heater, that you feed the pump some power and let i work until the diesel comes out of the pipe, this would prevent air getting into the webasto unit on first start up. Or alternative use a syringe to fill the pipe with diesel prior to final connection.
Post #93422 9th Oct 2011 3:57pm
cobs
Good idea - you could just connect the wiring loom up before finally connecting the fuel pipe - it needs some form of 'pulsed' supply (apologies to the electriccal experts who'll no doubt supply the proper term) to operate the pump which is controlled by the Thermo Top's circuit board. There was someone on the forum a while ago who'd built some bit of electroic equipment to do the same thing. When I've finished spud peeling duties I'll see if I can find the thread.
Post #93436 9th Oct 2011 5:14pm
cobs
re fuel pump pulse generator, it was Peter td4:
http://www.defender2.net/forum/topic5229.html?highlight=webasto[/quote]
Post #93447 9th Oct 2011 5:46pm
