Home > Puma (Tdci) > Webasto in Puma |
BigMike Member Since: 13 Jul 2010 Location: Lancashire Posts: 2253 |
There are loads of thread on this if you do a search
19th Sep 2011 2:24pm |
Look here
http://www.defender2.net/forum/post49777.html#49777 Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
19th Sep 2011 2:31pm |
cobs Member Since: 12 Jun 2008 Location: North Yorkshire Posts: 336 |
Am in process of mounting mine under front wing, driver's side just behind headlight. Will post some pics when I get a bit further
21st Sep 2011 6:33pm |
Chris Rogers Member Since: 28 Jun 2011 Location: Berkhamsted Posts: 28 |
fantastic - I'd love to see how you've done it.
I know there have been a few posts, but mainly seem to be from LHD users! |
21st Sep 2011 9:14pm |
thebigblue Member Since: 28 Sep 2011 Location: Elsinore Posts: 10 |
Any progress |
8th Oct 2011 1:37pm |
XS Pete Member Since: 13 Jan 2011 Location: Suffolk Posts: 632 |
Cobs has posted some more information here:
http://www.defender2.net/forum/topic8509.html Including links to some very detailed documentation he's written including pictures about the whole process. Pete |
8th Oct 2011 3:03pm |
thx
8th Oct 2011 4:53pm |
pic of the Thermo Top C during fitting
Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
9th Oct 2011 1:49pm |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 |
looks like a smart place.....same as D3? Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
9th Oct 2011 3:20pm |
Cobs - I read your extensive installation write-up.
Thanks for sharing, and taking the effort to do it. I understand it took a little while for the unit to power up, caused by lack of diesel flow. I would suggest to others that you prior to the final connecting of the fuel pipe to the heater, that you feed the pump some power and let i work until the diesel comes out of the pipe, this would prevent air getting into the webasto unit on first start up. Or alternative use a syringe to fill the pipe with diesel prior to final connection. |
9th Oct 2011 3:57pm |
Good idea - you could just connect the wiring loom up before finally connecting the fuel pipe - it needs some form of 'pulsed' supply (apologies to the electriccal experts who'll no doubt supply the proper term) to operate the pump which is controlled by the Thermo Top's circuit board. There was someone on the forum a while ago who'd built some bit of electroic equipment to do the same thing. When I've finished spud peeling duties I'll see if I can find the thread. |
9th Oct 2011 5:14pm |
re fuel pump pulse generator, it was Peter td4:
http://www.defender2.net/forum/topic5229.html?highlight=webasto[/quote] |
9th Oct 2011 5:46pm |
