Home > Technical > Laying up a LR
Surrey Rover
Laying up a LR
If I was to mothball a LR for a while (24 months), what is the best way to preserve the tyres?
It's going to live in a barn under a dust cover, but the temperature goes from 40 degrees in the summer to about minus 5 in the winter, the barn will help keep the weather out but the temps will fluctuate.
Is it best to let the some pressure out and just park up or let some pressure out and leave it sitting in axle stands with no ground contact or not bother doing anything?
Thanks for any ideas. Nick
2.2 110 Tipper
Post #93386 9th Oct 2011 12:38pm
T1G UP
off the ground leave them pumped up.
change the oils etc and make sure you have either drained the coolant or have enough protection in the coolant to cover the temp range.
disconnect the battery, remove and leave on a trickle charge.
Post #93395 9th Oct 2011 1:21pm
Happyoldgit
Try and keep the tyres out of direct daylight too. Steve.
http://forums.lr4x4.com
Post #93423 9th Oct 2011 3:57pm
Grockle
fresh oil, tape over the end of the exhaust, don't cover it unless well ventilated,spray silicone onto exposed rubber seals,if not on stands inflate tyres to 60 psi and leave a smear of polish on the paint 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #93426 9th Oct 2011 4:29pm
Zagato
Best to keep anti freeze/coolant in rather than drain as most have anti-corrosive properties and could grease the exposed swivels Thumbs Up
Post #93429 9th Oct 2011 4:37pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
damp and mildew.
with quite large temp fluctuations make sure you keep it aired as well BM52
Post #93431 9th Oct 2011 4:46pm
kingofthesparks
Location: Very close to Watford gap services , northants
United Kingdom 2012 Defender 90 Puma 2.2 HT Fuji White
24 months, hopefully you will get out earlier for good behaviour Rolling with laughter Rolling with laughter
Post #93432 9th Oct 2011 4:55pm
T1G UP
you could sell it
Post #93467 9th Oct 2011 7:15pm
Surrey Rover
T1G UP wrote:
you could sell it
Whaaat! No way, this one is a keeper
Thanks for the advice chaps. Nick
2.2 110 Tipper
Post #93471 9th Oct 2011 7:24pm
MK
Actually, Defenders for export come with max tire pressure., i.e. 83 lbs. I would leave it on axle stands unless I`m sure somebody will drive it from time to time.
In the old times people poured a bit of castor oil thru spark plug holes and turn the engine a couple of revs to avoid rusting. Puma 110" SW
Post #93483 9th Oct 2011 9:05pm
Caterham
you could lend it to me and I'll keep it 'aired' for you.
save the miles on mine too Very Happy
Post #93508 10th Oct 2011 7:22am
