![]() | Home > Td5 > TD5 Heater Fan |
![]() Click image to enlarge heater switch first stage swathes ground with resister - stage two or flat out bypasses resister to the motor check that you good ground the switch black wire with black spade on the end and male spade lug on the switch lever Last edited by dorsetsmith on 11th Dec 2021 5:53pm. Edited 3 times in total |
htb2 Member Since: 02 Nov 2018 Location: Carmarthenshire Posts: 538 ![]() ![]() |
Looks like an earth problem from the switch.
Tank Member Since: 25 Jul 2014 Location: Fife Posts: 431 ![]() ![]() ![]() |
Thank you, I'll have a look at that.
Electrics isn't my best out will see what I can do. Cheers Duncan |
Can I ask if there is a difference between the two green wires? Do they need to go a certain way round?
Thanks Duncan |
plug is pin 1 GS - green -slat gray
2 GY - green -yellow 3 Black and heater slide switch is ![]() Click image to enlarge |
Thank you
MC84 Member Since: 22 May 2016 Location: Near Bristol Posts: 360 ![]() ![]() ![]() |
Great and detailed information as always Dorsetsmith
![]() ![]() Hard Top 90 TD5 2001 Ford 100e 1959 www.youtube.com/mikemakesit |
So Dorsetsmith, it appears I have more than just this issue now!
Driving home from a weekend in Aviemore last night and I had the heated front screen on, the lights and I was using the windscreen wipers. I noticed that if I had the front heated screen on, and the rear as well that every time I used the wipers the speedometer dropped and the needle pulsed or flicked in time with the wipers ![]() Does this mean I have a major earth issue? How many earths does the TD5 have and where are they. I assume if one or all of them are corroded that this could cause not only the issue with the heater blower but also the other electrical gremlins I have discovered? Cheers Dunk |
start with your battery neg follow onto the chasse and then on to transfer box over to driver side under nether chasse to body work strap and in engine bay just behind coolant expansion tank earthing header
good place start with earth header C0289 K109 behind centre fascia (radio ) C0550 k108 engine bay just behind coolant expansion tank earthing header on the bulkhead have check earthing from battery . run temp wire down from the heater switch to the battery neg and see if this helps with your earthing problem under nether driver side chasse to bulkhead strap ![]() Last edited by dorsetsmith on 15th Dec 2021 10:32pm. Edited 1 time in total |
Thank you so much, really appreciated.
I had a lot of bulkhead work done with windscreen out and other bits off, wings etc etc. Maybe the earths havent been put back correctly. Regards Duncan |
Hi Dorsetsmith
So gets even more interesting now as there is a smell of burning, so my son tells me. I can't smell it as I am getting over Covid and have no sense of taste or smell! Where is the earth strap behind the dashboard is it easy to find? Cheers Dunk |
earth strap
Under nether vehicle on driver side between chasse to bulkhead |
OK
I'll get under the car at the weekend. Could that be the issue? Dunk |
![]() Click image to enlarge ![]() Click image to enlarge |
