Home > In Car Electronics (L663) > Land Rover Remote App & remote starting
Page 2 of 2 <12
L90Andy
United Kingdom 1997 Defender 90 300 Tdi ST Nato Green
Have you tried deleting the app and reinstalling? I had to do that on my L462 to get it to work, been faultless ever since.
Jag have just released a new version of the app with more features, worth looking to see if Land Rover have done the same. Instagram: L90andy
My 1984 Ninety: http://www.defender2.net/forum/topic56071.html - SOLD!
My 2015 Defender: http://www.defender2.net/forum/topic39625.html - SOLD!
Post #932812 8th Dec 2021 9:05am
Hairy Dan
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Chawton White
Yes tried deleting the app and reinstalling it and the bcm reset involves re-synching the app to the car but still no luck Confused Cheers Ian
22MY Defender 110 D200 SE, Fuji White.
Kielder 4x4 Safari
Instagram @defender_v8
Post #932884 8th Dec 2021 6:30pm
cyberhusky
Luxembourg
I never saw the start/stop button in the app. Neither in the old one nor in the new Remote app.
I think it has to do with the country you install the app, in many EU countries it is forbidden to let the car motor running, without moving it. 22MY Defender 110 (actual) | 10MY Freelander 2 (history) | 15MY Discovery Sport HSE (history)
Post #933002 9th Dec 2021 7:37pm
Blacksheep
[quote="Hairy Dan"]Yes tried deleting the app and reinstalling it and the bcm reset involves re-synching the app to the car but still no luck Confused[/quote
Did you manage to resolve your problem Ian?
Asking as I’ve got the same starting issues now! Time is precious, waste it wisely...
Defender 90 D200
Post #934402 20th Dec 2021 4:36pm
Huttopia
I know this is counter intuitive but have you contacted LR cust support? I had app issues on my D5 and they were sorted v efficiently. Also watch out for the app telling you it has timed out / car not started only to walk outside and find the engine running….it is just poor software dev and test. Once you commit to an app the overhead of ensuring it continues to work properly with all the Android / iOS releases is significant, and many companies don’t give provide the funding required to set up labs with all the different devices and operating system versions to test fully.
Post #934431 20th Dec 2021 6:59pm
J77
I’ve given up with the app, the rest of the car is running well. Other than the remote start, which I really don’t need, the app is of limited use. 24MY 90 D250 HSE, Tasman Blue
Post #934436 20th Dec 2021 7:13pm
Hairy Dan
No not managed to get it to the dealership yet but may try the route Huttopia has mentioned and contact customer services Thumbs Up Cheers Ian
Kielder 4x4 Safari
Post #934490 20th Dec 2021 11:49pm
TRGRichie
So far all good here, updated to os3 and app still works a charm.
I do find it weird that a lot of the faults reported only affect a few people, I suppose that’s what makes them hard to fix L663 90ht
Post #934591 21st Dec 2021 8:28pm
Kingfisher24
Remote App heating
My remote app will start the car but regardless of the temperature that I set on the app the car temperature does not change and it seems to only apply a low heat setting. First world problem! Should the settings in the car change when temperatures are selected on the app?
Post #937806 15th Jan 2022 8:20am
Hairy Dan
Just a slight update on this, my car went into the dealers on Tuesday and... it's still there! They can't find out what's causing the problem and are working with Land Rover Technical services to try and trace the fault. I know the lads in the service department and they've said that it is taking so long as they can't ring tech services, everything has to be done via email. So tech services say "try this" and they then email back saying "that didn't work" and have to wait for a reply which is taking a long time. I'm confident they'll get to the bottom of it and I've got a courtesy car so it's no real hardship. Thumbs Up Cheers Ian
Kielder 4x4 Safari
Post #939759 27th Jan 2022 6:15pm
Tim in Scotland wrote:
There was a dealer applied fix for the false theft reporting - mine suffered that issue in August 2020 along with quite a few other owners at the time. Seems odd that a similar fault returned after more than a year.
IIRC the fix was they disabled a signal input that made an antenna ground fault feed into the theft reporting routine. The logic being that if someone tried to rip the antenna off your vehicle then they were going to steal it. Software bods in a lab having a good idea but no practical knowledge of poor earths.
Shouldn't surprise anyone that is successive iterations of the software that bit of code has been re-introduced, or a helpful person has re-ticked a box they thought should be.
Post #939842 28th Jan 2022 11:22am
Hairy Dan
Well just to update and close this thread, I've got my car back and remote start works now Very Happy Apparently they have reflashed nearly every ECU on the car, at the instruction of Land Rover Technical Services, over the past couple of days, none of which worked. Eventually Land Rover sent up a new file to flash to the engine ECU and that seems to have fixed it Thumbs Up Cheers Ian
Kielder 4x4 Safari
Post #939914 28th Jan 2022 6:08pm
Page 2 of 2 <12
