Home > Technical > Low voltage at reverse light |
PCM Member Since: 25 Jan 2019 Location: North East Posts: 895 |
A bit of a puzzle this one.
I seem to be getting only 7v at the rear reversing light. 110 2014. Never noticed this before but after fitting a reverse camera that turns on when in reverse it sometimes works and sometimes doesn't. I'm assuming it's an earth but no idea where to check. Could it also be the reverse switch. Anyone any ideas on the best way to do a bit of fault finding as it's quite annoying.. Cheers PCM |
5th Dec 2021 11:23pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5789 |
It’s known for the tdci reverse light switches to play up, and that would be worth considering.
Get underneath unplug reverse switch, bridge the terminals, does light work? Then test switch for continuity |
6th Dec 2021 7:28am |
Bought a genuine reverse switch and while doing some soundproofing took off the cover under the cubby box.
Turns out that there was a plug above the gear box that had worked itself loose. Not really sure what it does but wonderfully when I plugged it back in the camera started working. 🙈 Turns out it wasn’t the reverse switch. But something far simpler. For once… |
17th Jan 2022 12:06am |
