Home > Technical > Number plate light/bulb
Fabio
Portugal 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
Hello All,
When I took the defender for MOT it came with an advisory for the number plate light, its not strong/bright enough. I checked and changed the bulb but nothing changed.
Does anyone have an Idea of what could be the issue? I have a week off work and thought I could try and repair it.
Thank you
Fabio
Post #932522 5th Dec 2021 5:40pm
Corroded connectors possibly, I’d suggest a Wipac LED replacement unit.
The factory number plate light suffers with a lot of corrosion related issues. Chillin In The BackwoodsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #932525 5th Dec 2021 5:58pm
I Like Old Skool
United Kingdom 1994 Defender 110 300 Tdi ST Coniston Green
Is this the standard Landrover light fitting? There should be two small bulbs and it is always worth checking the lens is clean as these often get gunked up with mud and moss as the fitting is poor and rarely watertight. If all is present and correct the lamp should illuminate adequately.
Post #932527 5th Dec 2021 5:59pm
Fabio
Thank you both, this is the standard Land Rover, it only has one light bulb, not 2.
Steve do you have a link for the Wipac led replacement?
FΓ‘bio
Post #932538 5th Dec 2021 6:40pm
https://www.ebay.co.uk/itm/373722175909?fi...Swsk9helvw
This particular one is good, straight fit no mods needed except for wiring connections.
Thumbs Up Chillin In The BackwoodsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #932539 5th Dec 2021 6:54pm
Fabio
Thank you Steve!
Post #932548 5th Dec 2021 8:05pm
πŸ‘πŸ» Chillin In The BackwoodsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #932553 5th Dec 2021 8:38pm
