Home > Puma (Tdci) > The strip down begins, TDCI head-gasket??
Page 7 of 8 <12345678>
Big Harold
Australia 2015 Defender 130 Puma 2.2 HCPU Alpine White
From your thread it looks like your problem is worse than mine.
I was loosing 500ml every 5000km.
I would get a coolant smell on and off when driving from the coolant hitting the exhaust.
I suspected a faulty cap as when you tighten right down seems ok for a couple of days.
The Iveco cap has an external drain fitting so I have connected a hose into a bottle to catch the overflow.
It is reported by other owners that have the same problem as a fix.
Your's however sounds way worse than mine and I would expect a head gasket.
The whole engine is extremely small and the head is very thin in cross section.
Keep us posted
Mark
Post #717446 13th Jul 2018 8:07am
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Big Harold wrote:
CaptainDan wrote:
Thanks Harold I will get in touch with them
Daniel
What are the simptoms of your engine.
Mine will loose coolant out of the header tank/ bottle from the cap centing.
I have just purchased an Iveco cap that has an external drain hose.
I haven't fitted yet but will let you know the results was recommended by someone on AULRO
Mark
Just what mine was doing, it was using coolant at an alarming rate, then it would eventually boil and go to limp mode,
Once stopped it would throw all the coolant or what was left, back up into the bottle and out the cap.
Once topped back up, and ticking over it would be fine for the next 5 or so miles,
No pressure in the circuit, I still can’t work out where all the water was going?
It was taking litres of coolant between stops, still running and towing great,
With no visible Steam/vapour from tail pipe?
I have a straight through exhaust with only a rear silencer (no CAT)
I’ve now done over 100 miles since putting it back together, and it’s been fine,
No coolant loss whatsoever. Thumbs Up 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #717473 13th Jul 2018 10:17am
CaptainDan
Australia 2013 Defender 130 Puma 2.2 HCPU Alaska White
Hi Ian
I am still working my way through the over pressure issue in the cooling system my new mech has not taken the head off as yet but has identified the hose around the back of the engine to the bottom of the overflow bottle has a 90 degree kink in it which may could be the cause of the lack of coolant flow. I will keep you posted on this.
My question today is how do you get the cast iron pulley plate off the front of the motor, just got back from taking a look at my vehicle and I see there are 4 or 5 bolts which we have removed but there seems to be another bolt or stud coming from the side of the alternator. I need to replace the pulley which the fan sits on, the bearing is shot and I see in the last of your photos you have the plate pulled forward and it seems to be pivoting on the bolt from the alternator side. Is this a bolt or a stud? does the alternator need to come off to get at this bolt? Also what is the best way to replace the fan pulley.
Thanks to anyone who replies
Daniel
Post #718532 19th Jul 2018 10:04am
Big Harold
I am away from mine at the moment but seem to remember something about the earlier models had a stud on one side.
Mine is 2013 I will be able to look on Monday if that helps.
Not sure if they are replaceable individually or the whole unit as one, a Ford unit might be an option.
Post #718536 19th Jul 2018 10:46am
CaptainDan
Yes mine is a 13 also it looks like a stud so you maybe right. These people seem to have all of the pulleys except the fan one
https://www.britishparts.co.uk/land-rover-...oners-c512
Let know how you go on Monday
Post #718539 19th Jul 2018 11:04am
Big Harold
OK
Just be aware that Ford cross reference parts are cheaper.
Timing Cover
Land Rover $302.95
Ford $73.95
Post #718542 19th Jul 2018 11:27am
CaptainDan
Thats a big difference I have a part number LR031367 for the assembly do you have a ford part number and supplier?
Post #718549 19th Jul 2018 12:29pm
ian series 1
You have to remove the alternator, and the water pump to access the two bolts either side of the front plate,
These are like hinges, so it swings down, after removing 3 other bolts on the front.
It’s all a bit of a lash up to be honest! 80" 80" 86" 88" 90"
Post #718550 19th Jul 2018 12:58pm
CaptainDan
Thanks Ian,
I think they may have forgot to put a bolt in on the water pump side as it just hangs by the alternator bolt once the front bolts are removed. Might have to replace the drive belt idlers and bracket as one unit (LR031367) do you know if they can be rebuilt or just replace as one unit?
Thanks
Post #718555 19th Jul 2018 1:09pm
dorsetsmith
Post #718559 19th Jul 2018 1:37pm
CaptainDan
Hi Guys can the fan pulley bearing be pressed out of the bracket plate and if so does anyone have a bearing number for it?
Thanks
Post #718716 20th Jul 2018 12:40pm
Big Harold
dorsetsmith wrote:
http://www.defender2.net/forum/post570203.html
Any update, just checking mine and it seems to have developed a liking for coolant.
Post #719575 25th Jul 2018 12:36am
CaptainDan
Hi Harold, Well the head has not as yet come off. Taking a look at the work which was done when the EGR failed the overflow pipe from the back of the engine to the expansion tank was kicked so the latest thinking is it could well be a coolant flow issue. I am just waiting for some uncoils to arrive from Adelaide and also hose connectors to remove the T pieces in the hose from the by pass work which was done by stuffing a steel rod in the hose and clamping it off. The hose work which was done to by pass the EGR was crap and the company here in Geelong should be truely ashamed of themselves. Not what you expect for $8.5K. I will keep you posted
Daniel
Post #719793 26th Jul 2018 9:30am
Big Harold
Hi Dan,
Can't figure mine out it has started using about 500ml of coolant/ 250km.
No sign of lost coolant. When vehicle is left for 12 hours while i'm at work and the coolant checked still has pressure in tank.
I can only think that maybe the head bolts are stretching and letting coolant into the combustion chamber.
I am going to try some head gasket sealant as I cant afford to have 2 Land Rovers off the road.
Mark
Post #719814 26th Jul 2018 12:06pm
materoforion
Australia 2010 Defender 110 Puma 2.4 SW Alpine White
Hi Ian,
Jumping into 2021, there's still not much resources out there to show how this is done (other than a haynes manual).
I've just bought my first defender and doing my research what I 'possibly' need to do to keep it running for a very long time.
I'm only envious of your ability to do such things and if and when it gets to that point, hopefully I'll refer back to you article as a resource.
Thanks again for sharing!
Post #932459 5th Dec 2021 1:28am
