Home > Technical > Grinding on full lock
Stevo5
United Kingdom 2012 Defender 110 Puma 2.2 USW Santorini Black
Very recently had my Fender get the full ‘Tweaked Spectre’ treatment-its got a lot of new suspension additions and when they took it for its road test they noticed that on full there is a really noisy grinding sound.
When I bought the car a year ago the previous owner told me that owner before him had done ‘something’ to shorten the turning circle. It’s never been a problem until all the new bits. Tweaked reckon it’s something to do with the bump stops?
Anyone had this problem before? It sounds horrendous and not sure if it’s doing any damage?
Any ideas on solutions?
Post #932415 4th Dec 2021 3:25pm
landy andy
I assume they are talking about the fact they have adjusted the steering stops in so now the tyres hit on full turn. Easy to adjust if you want.
Post #932418 4th Dec 2021 3:58pm
Stevo5
ok cheers it's due its MOT soon anyway so will get the local garage to have a look or take it to a specialist as it just sounds like it's grinding parts up on full lock.
Post #932422 4th Dec 2021 4:16pm
landy andy
In theory it should fail the MOT if the tyres are catching. Mine doesn’t fail, but he mentions it every year.
Post #932424 4th Dec 2021 4:43pm
Ianh
Easy to check, turn your steering on full lock and see if the tyre is making contact with the radius arm. If it does it will have polished the arm in the place it is making contact. Turn the wheel to full lock on the other side and check that for the same. As Landy Andy says, it’s simple to adjust the stops for you or any garage. Adjusting the stops so contact is no longer made on full lock will stop the rubbing but will increase turning circle.
Find it odd that the guys doing the work did not do the adjustment for you.
A search on here will give plenty of how to info for adjusting bump stops. Edit - Oops should have said lock not bump Embarassed
Just had a look at the picks of your truck on another thread. Not a surprise they are rubbing, you have moved from what looks like AT’s to much wider MT’s .
Post #932427 4th Dec 2021 4:59pm
miker
Who carried out the suspension works? Presumably new, wider wheels and tyres fitted too?
Anyone that's competent enough to fit suspension upgrades should be more than competent enough to diagnose and adjust the steering lock stops. If they're not, then I'd be taking it elsewhere to get the work checked over....
Post #932442 4th Dec 2021 7:12pm
Stevo5
To give them their due it was the final road test (it had spent all its time in workshops getting the bits fitted) on the day I was due to pick her up when they discovered the grinding.
Sounds like a straightforward enough job for local garage (I'm not that competent unfortunately) to sort out as I want to get out and drive her some more!
Post #932452 4th Dec 2021 9:19pm
I Like Old Skool
United Kingdom 1994 Defender 110 300 Tdi ST Coniston Green
I wouldn't be letting anyone work on my car that couldn't sort Defender tyre rubbing at full lock in 10 minutes (and that includes walking into the workshop twice because they picked up the wrong size spanners the first time!).
Can't remember if the bolt and locknut are 17mm or 19mm.....
Post #932454 4th Dec 2021 11:03pm
It is rather worrying that a firm undertaking such a major package of modifications, especially in safety-critical areas, would consider handing it back in this condition. Tyre rub on full lock should have been addressed as a core part of fitting such oversized wheels, it shouldn't be an afterthought. It also something so simple and fundamental it is hard to understand how it could be ignored. Some other aspects (such as the top damper mounts mentioned in one of the other threads) also raise doubts about the competence of the convertors.
I'm afraid it rather makes me wonder whether it is the vehicle or the owner who has been "tweaked".
Post #932465 5th Dec 2021 7:59am
Stevo5
Well I dont feel cheated if thats what you mean! Road testing was done at the very end (literally the day of pickup) of the process as the vehicle was stripped essentially in plaxe and then all the many parts added.See picture below early on in the build. The quality of the work is outstanding. Took it stime and comms could have been better at times but all in all I'm a very happy camper without all the doom and gloom coming from some quarters on here.
Sounds like a pretty simple thing with the bump stops and with the Terrfirma parts that have been highlighted thats the first I've heard about them so will do some more research.
It's now a unique model (only Utility they have converted in UK so in a class of 1 so far) that will hold its value very well I believe.
Post #932474 5th Dec 2021 10:48am
landy andy
Yes. Very simple to adjust just need a spanner, and reall easy for the garage to do if they use a ramp as it will put it at a nice working height.
Hope you enjoy your Defender that is what it is all about at the end of the day. 👍🏻👍🏻
Post #932480 5th Dec 2021 12:15pm
It will be lockstops rather than bumpstops but is a very easy and quick adjustment.
You have created a very striking Defender and are clearly delighted with it, and ultimately that is what matters. I hope it continues to give you max pleasure for many years. I bet your grin when driving is as wide as the tyres!
Post #932484 5th Dec 2021 12:45pm
Stevo5
Duly noted all and will gte the garage onto this asap-not too sure how much weight the build has added so hopefully their ramp will be strong enough.
Post #932497 5th Dec 2021 2:13pm
MichaelE
I think you need to consider that it may not be anything to do with stops, and it's just the power steering fighting against full lock. My 1993 90 makes a noise on full lock. So does my 1987 110. And the 2 year old Mercedes van that I drive at work does, but to a significantly lesser degree. Barely perceptible but I can hear it, and see the extra vibration in the door mirrors.
Post #932549 5th Dec 2021 8:17pm
Mo Murphy
Could be a knackered CV joint 👍
50 Shades of Pennine Grey
Post #932554 5th Dec 2021 8:57pm
