Home > Puma (Tdci) > Rear seat rake adjustment
DarrenJ
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Has anyone found a way of adjusting the rake of the rear drop down seats in the puma 90?
Cheers Darren
Post #148596 4th Jun 2012 5:02pm
Minch90
Bit of an old thread, hopefully enough time has elapsed for someone to have figured how to make the drop down seat backs less upright… 2.4TDCI 90 - everyday brilliance
S3 V8 Lightweight - in the garage being ignored #newchassistime
S3 lightweight - 2nd car 24V fire risk with a full tilt and the windscreen down
S1 80" - first car fun - 75mph in neutral downhill once #wobblesallround
Post #929682 14th Nov 2021 11:05am
skidrov
Australia 2010 Defender 110 Puma 2.4 SW Fuji White
Far Corners have a product:
https://farcorners.co.uk/product/far-defen...at-risers/
...but you may find the timeliness of response variable. I have these, they fit/work well, but it took a while to complete the transaction.
Edit: sorry, just noticed the question is about a 90. My answer is probably not relevant!
Post #929785 15th Nov 2021 8:12am
AMBxx
Just turn up the radio - should drown out any complaints coming from the rear.
Post #929813 15th Nov 2021 12:00pm
MatLandy
France 2008 Defender 110 Puma 2.4 CSW Zermatt Silver
For the forward facing folding rear seats in a Puma (3rd row on a 110, 2nd row on a 90), there is a possibility to remove some bushings in the hinges mechanism to recline the seats further. I reckon I gained about 3 to 5° angle between the seat base and seat back in doing so.
Not a world of a difference, but every little help as they say.
I unfortunately do not have any pic, as this was done long ago.
From memory, you need to remove the seat back cover and foam, as well as the plastic part covering the hinge assembly on both sides of the seat. Once done, fold the seat back a few times to understand how the mechanism works and you should realize which bushings shall be removed. For each seat, it's a rubber insert on one side and more of a metal washer that is partly welded around a stud on the other side (just grind it off and remove the metal washer, not the stud).
/Mat
Post #932288 3rd Dec 2021 10:39am
