Home > My Defender > What Did You Do In Your Defender Today |
kenzle8a Member Since: 12 Feb 2020 Location: None Posts: 1074 |
Click image to enlarge |
2nd Dec 2021 12:27pm |
Ihod Member Since: 07 Nov 2015 Location: Berkshire Posts: 165 |
Click image to enlarge Ian MY1998 300Tdi 90 Hard Top (Now Soft Top) MY2015 110 XS SW - Sold MY2008 110 County USW - Sold MY1962 Series IIa Truck Cab - Sold MY1994 300Tdi 90 Hard Top - Sold MY2001 TD5 90 Truck Cab - Sold |
7th Dec 2021 11:02am |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10733 |
Cant beat a " in the field " pic 1996 Golf Blue 300Tdi 110 Pick up. Keeper. Clayton. |
8th Dec 2021 9:41pm |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3410 |
An innocent little puddle turned out to be a 1 meter deep hole 😩
Tried the usual tricks of trying to fill the hole with rocks..but I could not pull myself out with one wheel barely touching the slippery surface. Time to call rescue 🤠Luckily I was going very slow, so just a little bent bumper.. easy fix. Although I need to check the sill, as the side steps might have pushed it up a bit (door is rubbing now). Click image to enlarge 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
12th Dec 2021 5:39pm |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3671 |
Oops!! I hope the stainless lower grille is ok!!
12th Dec 2021 6:08pm |
Yeah...was an ooops moment. The grille is perfect..and not even dirty 😊
This pic should show that 🤓 Click image to enlarge 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
12th Dec 2021 6:42pm |
Race.it Member Since: 27 Aug 2019 Location: Algeciras Posts: 815 |
Passed the annual inspection Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details |
13th Dec 2021 8:54am |
Replaced the ignition switch:
Click image to enlarge More details here: https://www.defender2.net/forum/post933318.html#933318 Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
13th Dec 2021 9:10am |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2638 |
Finally got the double-din dash + new radio fitted, Madman neatly mounted on the side as well.
Click image to enlarge Click image to enlarge -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
13th Dec 2021 3:08pm |
johnnyha Member Since: 08 May 2019 Location: London Posts: 40 |
Nice work |
14th Dec 2021 11:54am |
Smyles_ Member Since: 25 Aug 2018 Location: Copenhagen Posts: 517 |
Hey Naks, any chance you could tell me how much room there is behind those side panels. Looking to install a rather deep temp/pressure gauge there myself but the whole truck is in pieces currently so can't find out myself Gauge in question: Click image to enlarge(the bend protected pipe is the limiting factor not the black pressure pipe) Stuart Cummins 130 Build Thread 58 130 Double Cab HCPU - Cairns Blue 04 110 Double Cab - Black (gone) 07 Audi RS4 Avant - Silver |
14th Dec 2021 12:15pm |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3745 |
^ That looks pretty deep if you have the double din unit in also, its all a bit tight behind them.
The angle that gauge goes in looks to be the brass type connection would fowl the radio? I will try and get a picture of my side panel as its quite easy to clip off (another job I need to do is fix it in better) ---------- My Defender job was Drive to Garage, MOT. Passed first time -------- Click image to enlarge |
14th Dec 2021 1:18pm |
Thanks Stacey, would be very much appreciated!
No double din to worry about (personally think they look naff with all the tacky shiny plastic) and the large connector for the backlight is between the 2 and 3 o'clock position with the other two at 6 and 12 if that makes sense. Basically holding the gauge upside down in that photo so there is nothing on the left hand side as you look from the face side with the lengths of threaded rod being for mounting so can be lopped as required. So with everything being to the right I think I can bag a little more room Congrats on the MOT! 110 looking very classy with those mud flaps and no window tints Stuart Cummins 130 Build Thread 58 130 Double Cab HCPU - Cairns Blue 04 110 Double Cab - Black (gone) 07 Audi RS4 Avant - Silver |
14th Dec 2021 8:34pm |
OK not very scientific but there seems to be a lot more room than I thought, the angle must be enough to keep it away from the double din unit.
I used a cleaned yogurt pot to push in the hole... now I have a USB cable coming out of said hole so it was a quick job on the school run as I didn't want to push the cable back through. To my surprise you have a fair bit of room. You can see the cable actually stopping it. it would go a bit further and worse case you could space it out at the front slightly with a large rubber washer? Click image to enlarge I reckon you have a good 60mm Maybe more, I'm due out soon so when parked up will have another look. |
16th Dec 2021 9:28am |
