Home > Maintenance & Modifications > Wiper arm sweep
excossack
Wiper arm sweep
Is it possible to adjust how far the wiper arm sweeps? On the drivers side the wiper arm does a good job of wiping the windscreen rubber and I would rather the wiper didn't.
I have the arm set so its about as low as it can get when resting, but in operation, it sweeps too far. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #931979 1st Dec 2021 9:38am
geobloke
Must have read my mind Rolling with laughter
Your wish is my command Thumbs Up
https://www.carbuilder.com/uk/wiper-gears
Post #931981 1st Dec 2021 9:42am
geobloke
Believe 115 degrees is normal.
Or you can DIY it https://youtu.be/EpG9P6auilk
Post #931982 1st Dec 2021 9:44am
excossack
Cheers. So the only way is to replace the cog in the wiper motor? 1999 Defender TD5 110
Regards
John M0VAZ
Post #931983 1st Dec 2021 9:45am
geobloke
Yup that's what controls the sweep.
Post #931986 1st Dec 2021 9:47am
excossack
Very useful - thanks. I think I need more like 100-110 degree sweep.
If 115 is standard then I wonder why my wiper likes to clean the windscreen seal ? 1999 Defender TD5 110
Regards
John M0VAZ
Post #931994 1st Dec 2021 10:17am
geobloke
How much play do you have in the wiper arm? Usually when Defender wipers start hitting the windscreen seal it is that there is play in the wiper wheel box or in the spindle. It is worth checking that the wiper nut has not come loose as well.
Post #931998 1st Dec 2021 10:25am
geobloke
And I think I was wrong. I think that 110 degrees is normal, although mine do not seem to go past 90 degrees.
When I next have a look in the dash I will check what cog is in there.
Post #931999 1st Dec 2021 10:27am
excossack
I have recently done new splined adapters and new wiper arms. There is a little bit of play but not what I would call excessive.
Wiper nut ? just splined adapters and a grub screw on my wiper arms. 1999 Defender TD5 110
Regards
John M0VAZ
Post #932000 1st Dec 2021 10:27am
geobloke
Ahhhhh Ol'skool wiper wheel boxes Rolling Eyes Notoriously finicky with the habit of welding completely together over time. Or flopping about like a wet fish... Rolling with laughter
Post #932003 1st Dec 2021 10:31am
excossack
Yup old skool! They get replaced a good few years ago with new LR wheel boxes. Not doing the job again..... 1999 Defender TD5 110
Regards
John M0VAZ
Post #932005 1st Dec 2021 10:33am
geobloke
Well just for completeness sake
Pre 2002 - 1A 622423 VIN - 517646 - 110 degree sweep
Post 2002 - 2A 622424 - DLW000020 - 140 degree sweep
Which is interesting because My 2003 definitely does not sweep 140 degrees Rolling Eyes
Land Rovers, nothing is ever straight forward... Rolling with laughter
Post #932011 1st Dec 2021 11:09am
geobloke
Yeah not a fun solo job, but worth it for decent wiper motion Smile
Post #932012 1st Dec 2021 11:09am
geobloke
Well that seals that then... A little look back in the DIY archives and...
Those VIN change over points mean jack... Rolling with laughter
When it comes down to stuck wiper arms on spindles, this is what id did to get mine off. May help someone else at some point.
Post #932018 1st Dec 2021 11:32am
excossack
A 115 degree wheel
I had to do similar to remove my splined spindles. 1999 Defender TD5 110
Regards
John M0VAZ
Post #932019 1st Dec 2021 11:42am
