Home > Maintenance & Modifications > How much fluid is needed to flush clutch master cylinder? |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3414 |
Not on a tdci, but used less than half a bottle of 250ml on an lt77 master/slave. And that was with some accidental waste as the slave piston got pushed out (engine is still out).
PS. I use dot5. That stuff seems to come in 250ml only bottles locally as is damn expensive. Reason for dot5 - if the master leaks, it does not eat the paint off the bulkhead. Something to consider? https://www.defender2.net/forum/topic78646.html 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
20th Jul 2021 8:44am |
Leamreject Member Since: 19 Dec 2020 Location: Middle Earth - Leamington Spa Posts: 970 |
As a precaution I would avoid using Dot 5, it may not damage your paintwork but is silicone based and can’t be mixed with dot 3,4 or 5.1.
It’s not really intended for road vehicle use. Ride like you stole it!! If I’m not on a bike it’s because only a 4x4 will do… 2011 2.4 Puma 90 HT |
20th Jul 2021 8:51am |
I do not think the clutch hydraulic is a critical component. But I also do not know why dot3/4 is specified for the clutch fluid. I hear somewhere that manufacturers just specified dot3/4 for the less technical people so that they do not mix up brake and clutch fluid.
How many people wanted to buy the 710 fluid? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
20th Jul 2021 11:44am |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5698 |
I used LOADS. was a too bleed. Had to get reserves in.
20th Jul 2021 6:58pm |
LandymanStefan Member Since: 30 Aug 2017 Location: Surrey Posts: 881 |
Just got a lof powerslave delivered. Is it ok to use dot 5.1 in a td5 clutch systemas i already have some in the garage.
Thanks |
27th Nov 2021 11:02am |
