Home > Puma (Tdci) > Clutch grinding noise |
Angus_Beef Member Since: 30 Apr 2015 Location: Oslo Posts: 434 |
When mine did this it was a clutch spring touching the pressure plate
Click image to enlarge Roaming around 🇳🇴🇨🇭 |
23rd Nov 2021 5:01pm |
wyvern Member Since: 13 Dec 2009 Location: Cornwall Posts: 2117 |
i had exactly the same symptoms on our previous 2.4 110, the clutch springs had sprung so had to be replaced - got it home with a bit of careful driving and then got the main dealership to replace the clutch - all done in 4 hrs with me waiting !
Now got to have the clutch in the 2.2 changed as its not behaving its self ... ho hum ! Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 |
23rd Nov 2021 5:48pm |
chrisc2306 Member Since: 02 Jan 2020 Location: Glasgow Posts: 60 |
Thanks for the replies I’d hoped it was going to be something a bit easier but have just bitten the bullet and ordered a new one from lof with a new output shaft for good measure. Hopefully it’ll be cured after that
23rd Nov 2021 6:27pm |
Ive does the same and bought a Power clutch but have had to order an Ashcroft shaft as they didnt have any LOF ones when I was buying ...
23rd Nov 2021 6:29pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20472 |
This is what mine did, I had to admit defeat in the end that the Master Cylinder wasn’t going to cure it, but, all the same was not a bad thing to be replaced.
Though I had very low fluid as well, I’m tending to think it’s a clutch spring issue with mine as well. So far I fitted a new Genuine MC myself. That was fun! Bled it. I’ve got the updated slave, valve and adaptor ready to go in Gen LR. I’m waiting currently on the Transit 4x4 clutch to arrive, which is heading my way. I’m going to get the flywheel in case and the same with the intermediate shaft in case they are needed. Factory LR Clutch went on mine at 40k, the second updated genuine one went at (88k 48k later which I had better hopes for. I’m not that impressed with them hence the swap to the Transit clutch this time. No Guts, No Glory. 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
21st May 2022 10:27pm |
