Home > Puma (Tdci) > Brake issue
Silver110
England 2008 Defender 110 Puma 2.4 XS CSW Zermatt Silver
Brake issue
Evening,
I had the common issue where the brake vacuum pump spits all its oil out, so I replaced the vacuum pump and then had an issue where if I use the brake on off in quick concession then pedal would just harden up and brakes not work.
I put this down to a fault pump due to not happening before the oil leak.
I have since put a second pump on and noticed when I took it off there seemed to be minimal oil in and around the pump. Now the second one is clicking away as if it’s running dry.
What would stop the oil getting to the vacuum pump. Is it engine oil or brake oil and does it have a seperate tank?
Does it need bleeding?
TIA!
Post #929651 13th Nov 2021 11:27pm
If it is a 2.4 (which from your description I suspect it is) the vac pump is fed from the engine lubrication system and has feed and return passages through the mounting surface. The only reason why it would not be getting the oil feed would be if the gasket has been fitted incorrectly or if an oil passage is blocked.
The hard pedal fault you describe suggests that the pump is not creating vacuum fast enough and does suggest either that the pump was faulty or possibly there was a leak in the vacuum pipe after you refitted it.
There should be no brake fluid anywhere near the vac pump, only engine oil, and as noted above it is fed form the engine's pressurised lubrication system and needs no bleeding.
Post #929653 14th Nov 2021 12:03am
MadTom
Czech Republic 1999 Defender 130 Td5 HCPU Baltic Blue
Check for vacuum leakage. I had to replace brake servo on two cars, because it had broken outer steel body and was loosing vacuum. It was only slow leak, first breaking was normal, but repeating breaking leaded to hard pedal. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #929666 14th Nov 2021 7:25am
Silver110
Thanks for the info,
I believe it’s something to do with oil to the pump as the brakes were fine it’s only if you use them in quick concession as if you were doing a 5 point turn for example.
The other tell tale is that it is ticking quite loudly. If I was to take the pump off and start the engine I’m assuming there will be a ton of oil pour out one of the holes?
Trying to think of a way to test it.
Post #929672 14th Nov 2021 10:10am
Dinnu
Ensure that the vacuum pipe between the pump and the servo is not collapsing, restricting the air flow rate. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #929679 14th Nov 2021 11:57am
landy andy
Have you checked the servo is empty, and not full of oil? You can use a cable tie as a dipstick.
Post #929683 14th Nov 2021 12:29pm
Silver110
Sounds interesting how would I do this? Where would I dip it?
Post #929703 14th Nov 2021 3:39pm
Silver110
This is next on my list!
Post #929704 14th Nov 2021 3:39pm
Race.it
Spain 2010 Defender 110 Puma 2.4 SW Alaska White
Take off the vacuum pipe on the servo and use that hole? Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details
Post #929713 14th Nov 2021 6:05pm
Silver110
Servo is empty of liquid and can’t see any issue with the vac pipe. Took it off the servo and put the vac onto my finger and had suction.
I’ve also recently installed the LOF power spec discs and pads
But don’t see that being an issue.
Have searched through hole car whilst on ramp and can’t seen any leaks.
Post #930623 21st Nov 2021 8:09pm
Silver110
Does anyone know anything about bleeding the ABS system? Thinking it may be linked to that.
Post #930873 23rd Nov 2021 7:49pm
Bluest
There’s a procedure in the workshop manual for power bleeding the pump and brakes. You need a diagnostic tool that can actuate the ABS pump. I did it last year after removing and refitting the pump. I pressure bled the brakes conventionally before following the manual to power bleed. To be honest, I couldn’t get any more air out power bleeding, so I think it can be done the old fashioned way. 2007 110 TDCi Station Wagon XS
Post #930877 23rd Nov 2021 8:15pm
Silver110
Thank you.
Back to the drawing board, frustrating.
Post #931043 24th Nov 2021 10:02pm
