Home > V8 > 3.9 efi Air Box mount
gbmoto
Hi All
Recently bought this 90 with a RR 3.9 efi.
Generally well done but a few bits I want to change.
One is the air filter, currently it has a K&N which I am going to replace with a modified standard RR box in the same position as a 50th Anniversary/NAS, so behind the engine mounted on the bulkhead.
Does anyone have a picture of the mount without the air filter attached please?
Post #929209 9th Nov 2021 11:01am
Lodelaner
United Kingdom 1988 Defender 90 V8 Petrol ST Shire Blue
Hi - I've done the same conversion. The air filter has a collar that goes around the neck and mounts to a bracket on the back of the engine using either a plain bolt/nut or cotton reel rubber buffer jobs.
I know some people fix it to the bulkhead, but it's easier/neater not to.
I haven't got a photo without the air box - but I can take some photos when I get the Landy out next.
 JB
@Lodelaner Instagram
Youtube greenlaning and other LR related content
Post #929976 16th Nov 2021 3:10pm
gbmoto
That's a nice install Lodelaner.
I was reckoning on cutting and rewelding the filter to "straighten" it, but I see you have rotated yours, deffo stealing that idea!
I guess you pick up on the engine lift bracket bolt holes?
Post #929978 16th Nov 2021 3:40pm
Lodelaner
I can’t remember which bracket it goes onto (brain fade)! I’ll get that photo for you 👍 JB
Post #929979 16th Nov 2021 3:47pm
Lodelaner
Thx for the kind comments. Yours looks good- I like the doors and wheels (my next 2 jobs).
Ah yes, using the kink in the air box inlet (from a flapper EFI) means the airflow meter clears the heater box and you don’t need a complex up and down air intake pipe from a NAS. Mine uses a combination of the D1 V8 intake and regular intake pipe from the flapper V8 going into the plenum. JB
Post #929980 16th Nov 2021 3:52pm
gbmoto
Ta muchly, useful info, a lot simpler than my original plan!
I like simple Very Happy
I have had a look at your 90 in your gallery, it is sooo nice, ironically I want to go with Wolf's and 235's ultimately. It came with the 265 BFg's on eight spokes so swopped them to the freestyles for a sort of NAS/50th look.
Also plan to de-chequer plate it over time.
Post #929981 16th Nov 2021 4:03pm
Romadog
Bracket is one shown below. NLA at JLR and only on V8 engined 50th Anniversary vehicles in this country.
http://new.lrcat.com/#!/1228/20326/20390/1554
Post #930658 22nd Nov 2021 9:25am
gbmoto
Many thanks Romadog, much appreciated.
Post #930660 22nd Nov 2021 10:15am
gbmoto
Well finally got this fitted. big alloy plate bolted to the engine lift plate holes.
Still a fair bit of tidying but runs a lot nicer and quieter.
Fast tickover to start with until I found the throttle cable had been adjusted up to "correct" a low tickover caused by the K&N Laughing
Will connect up the laptop again soon and see how things look now.
Post #953105 21st May 2022 3:54pm
Van Diesel
United Kingdom 1986 Defender 90 V8 Petrol ST Auto Pennine Grey
I bought mine with a K&N already fitted. Whats the main benefit of switching back to a RRC intake?
Post #954219 31st May 2022 6:40pm
Lodelaner
Probably not worth switching back.
They do create more induction noise (allegedly), can contaminate the MAF / hotwire and need oiling.
I just junked one off my D2 and went back to paper. JB
Post #954241 31st May 2022 8:59pm
Van Diesel
Fair enough, I've just cleaned and re oiled this one but it seems to have dried out quickly with all the heat generated under the bonnet.
Post #954242 31st May 2022 9:04pm
gbmoto
In the case of mine the engine hadn't been set up properly for it, runs much nicer now and noticeably quieter.
Maybe slightly less powerful but a tweaked 3.9 in a soft top 90 still is plenty zippy Very Happy
Post #954272 1st Jun 2022 7:41am
MercianRover
United Kingdom 1998 Defender 110 300 Tdi CSW Java Black
The oil from the K&N gets inducted as a mist, coats the hotwire sensor and degrades it's performance.
Also a K&N is a very poor filter, better off retaining the paper element and keeping the inside of the engine grit free. The "performance" benefits of the K&N are negligible.
Post #955551 15th Jun 2022 8:42am
Van Diesel
Yep, I've umm'd and ah'd over K&N filters for decades with a multitude of vehicles and never gone down that route.
This was on when I bought it. It was clogged up and very dirty. I cleaned and re oiled. Is it possible the new oil has got onto the wire on the MAF and causing the problem? Bit delicate to clean the wires I believe even with carb cleaner?
Post #955642 15th Jun 2022 8:53pm
