![]() | Home > Technical > 2011 Defender Horn Failure |
fuse 27 under dash fuse box
https://1drv.ms/u/s!AtZSoWFHDgnGlkisYCA8iDgYfVxD?e=IjJwqe
look under alarm then you open the file it will ask how do you wont to open pick PDF two missing fuse from wire diagram think martin ![]() Click image to enlarge ![]() Click image to enlarge |
Donald.e Member Since: 03 Aug 2021 Location: Evanton Posts: 27 ![]() ![]() |
Cheers, the alarm sounder is good, but will check all this out
stanley Member Since: 18 Sep 2009 Location: Dorset /hampshire Posts: 1033 ![]() ![]() ![]() |
Check the wiring behind the O/S headlight , mine had chaffed through
alarm sounder and horn on same page of the wire diagram ![]() |
OJ Member Since: 23 Nov 2018 Location: North of Edinburgh Posts: 121 ![]() ![]() ![]() |
Had exactly the same problem, thought it was my grandson yanking on the stalk that broke it but turned out both horns had failed, think one failed a while ago, didn’t realise there were two, replaced and all ok, access by removing the headlights and pots, I tried removing them first and tweaking the grey adjustment screw, they worked fine for a few days then had to do it all again to replace them
