Home > Maintenance & Modifications > Loose wing mirror |
AMBxx Member Since: 24 Jul 2016 Location: York Posts: 1032 |
My passenger side wing mirror is loose where it attaches to the hinge.
As far as I can tell, I need to remove the front part of the hinge to tighten up from behind. As those bolts aren't captive, it's going to be a faff and will need the door to be realigned. Is there a clever way to go about this? |
7th Nov 2021 3:42pm |
Needless to say, I have security plates on the inside of the hinges. Thanks for the tip on marking. I'll give it a try next weekend.
7th Nov 2021 5:57pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17441 |
Your security plates won't make any difference for this job. The jury's out on whether they do anything useful security-wise, sadly probably not, except perhaps provide a certain peace of mind.
7th Nov 2021 6:14pm |
Ramsay Member Since: 30 Sep 2015 Location: Moffat, Dumfries & Galloway Posts: 627 |
You should get some MRC1979 plastic washers as the reason why screws are loose may be that they are missing. 1995 Defender 110 CSW
1971 SIIA Lightweight |
7th Nov 2021 6:56pm |
