Home > Puma (Tdci) > Puma 2.4 2009 Starts on 2nd,3rd or 4th try |
Arsath Member Since: 20 May 2015 Location: Sri Lanka Posts: 133 |
Hi Folks,
I am having a very strange issue with my Puma 2.4 lately. The car takes too many tries to start, but most definitely it starts. When it's been idling for let's say longer than a day the issue worsens. When I crank the engine it makes this painful noise. Have a listen https://soundcloud.app.goo.gl/VNPf9 What could be the problem? My battery is brand new, I checked the terminals and they are snugly fit. Anything else I should check? Also I have done the basic BAS Remap and disabled the EGR. (can't think how it could be related anyway) Please help.. |
3rd Nov 2021 1:38pm |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3414 |
Sounds like the bendix is slipping (part in the starter). 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
3rd Nov 2021 2:19pm |
jpboost Member Since: 13 Apr 2021 Location: Gatwick Posts: 377 |
yep, I'd be putting a new starter on that.
3rd Nov 2021 2:48pm |
Gents, one thing that I forgot to mention was, I have also fitted a Push Start unit, I was sick and tired of the ignition unit and decided to altogether ditch it for electronic push start..
Anyone think that could faulty? |
3rd Nov 2021 6:14pm |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 1997 |
Have a look at this, worth checking the new starter button connections as well.
https://www.defender2.net/forum/topic56604.html |
3rd Nov 2021 6:33pm |
Yes, that could definitely be (part of) the problem. Over the years I've always found that in car systems (electrical and mechanical) any non standard parts or non standard configurations have a higher chance of being the source of any problems. Even high quality parts that have been fitted to a high standard. So, if there's anything non-standard in the system, I'd certainly be checking (and double checking) that as soon as possible. |
4th Nov 2021 9:14am |
Click image to enlarge Hopefully found the issue.. |
6th Nov 2021 11:48am |
Thanks everyone for all your advise.. Changing the starter motor brushes solved the problem.
7th Nov 2021 7:21pm |
