Home > V8 > GEMS Rover v8 with a manual transmission
Page 3 of 3 <123
mikeh501
I had exactly the same problem with tight fitting xfer box mounts.... turned out id fitted an lt77 v8 bellhousing which is 25mm longer! i didnt find out until it was all built. worth a quick measure. 275mm.
Post #911502 8th Jul 2021 7:56pm
Hufflepuff
Mr Ashcroft kindly sourced it for me so I'm sure it will be correct, but I will get the tape measure out this weekend, thanks for the tip Mike. 2005 Td5 90 XS
1989 V8 110 CSW
Post #911507 8th Jul 2021 8:34pm
Shroppy
United Kingdom 1986 Defender 130 V8 Petrol HCPU Aintree Green
Hufflepuff, do you have the part no. for the manual crank sensor mount handy please? 1985 127 V8 Build Thread
Series 2 109"
Series 1 80"
Post #928242 2nd Nov 2021 4:48pm
Hufflepuff
Hello Shroppy, I bought a complete new sensor which came with the mount, as per:
I can't for the life of me remember where I ordered it from though, I should have an electronic receipt somewhere but my filing system is, er.. a work in progress.
The sensor part is ERR6119, but as this is the same sensor for both manual and automatic, that doesn't help much. I've googled the usual suspects and they are not making it clear which part number is for the manual.
The following item (use the 'Lucas' pulldown for the brand) lists the same number as my box above - but the picture does not show the mount at all so all bets are off. Could give them a ring and ask? It says its in stock.
https://www.lrparts.net/err6119-engine-cra...ery-1.html
Or you could do what Roland instructed me to do (which I didn't understand at the time) and just grind down the automatic mount if you have that already? 2005 Td5 90 XS
1989 V8 110 CSW
Post #928256 2nd Nov 2021 5:33pm
Shroppy
Many thanks Hufflepuff, I'll give them a call as you suggest.
Would you be able to tell me the thickness of the manual mount if possible please? Just in case I do need to cut the automatic one down. 1985 127 V8 Build Thread
Series 2 109"
Series 1 80"
Post #928278 2nd Nov 2021 8:13pm
Hufflepuff
Yes I can do - let me know if you do decide cut yours down. I don't think its a terribly precise size, it just needs to not bottom out the sensor in the reluctor ring.
Looking at the image, it looks about twice as thick as the bottom plate. 2005 Td5 90 XS
1989 V8 110 CSW
Post #928284 2nd Nov 2021 8:29pm
Page 3 of 3 <123
