Home > Puma (Tdci) > FIXED - Starting issue after Head Gasket change
Greyman110
What could be touched that could impact starting?
This is only when it’s warm and only started after the HG was replaced.
So far I’ve replaced the diesel return pipe and all 4 injectors on the advice of the garage.
I also saw the fault code U0001 and engine warning light so could that be the CAN BUS?
It’s been back to the garage twice and I’m not getting anywhere except much poorer!!
Post #927242 26th Oct 2021 6:19pm
Greyman110
So after some research, I disconnected the CHT and cleaned with contact spray and that seems to have solved the warm start issue!
Since doing that its started first time every time so fingers crossed thats it sorted.
Post #927847 30th Oct 2021 5:08pm
90 Dreamer
CHT ??
Post #927859 30th Oct 2021 6:34pm
Greyman110
Cylinder Head Temp gauge that sits on the top of the engine at the back.
Post #927860 30th Oct 2021 6:35pm
90 Dreamer
Post #927862 30th Oct 2021 6:37pm
Greyman110
Post #927863 30th Oct 2021 6:38pm
