Home > Puma (Tdci) > land rovers that use the same diff as rear diff on puma 110
Sam smith
United Kingdom 2009 Defender 110 Puma 2.4 HT Epsom Green
hello
does anyone know what other landrovers use the same diff that is found on the rear of a puma 110?
thank you!
Post #927799 30th Oct 2021 11:02am
htb2
Wales
Discovery 2 rear and I think P38 Range rover. Mind you tried to remove one from Disco2 but axle too rusted to get rear shafts out, sledge hammer fail.
Post #927802 30th Oct 2021 11:46am
Disco2 uses a Rover-pattern long nose diff which won't fit a Puma LWB rear axle. As far as I know the P38 diff was only ever used on P38 front and rear, so nothing else provides a donor source (except another LWB Puma).
The P38 diff was made in both 2- and 4-gear versions but fours are hard to find. Twos are easy to find and cheap and provide a.great basis for a locker build.
Post #927803 30th Oct 2021 11:55am
Sam smith
ok thank you
that was my concern. im struggling to find a used rear diff at a reasonable price. any ideas as to where i could find one. Ive tried multiple breakers but no luck yet
many thanks
Post #927831 30th Oct 2021 2:20pm
Sam smith
so would a 4 pin RR p38 rear diff not work in my puma 110?
cheers
Post #927832 30th Oct 2021 2:27pm
ashtrans
Site Sponsor
Yes that would fit Dave
Post #927836 30th Oct 2021 3:17pm
It is not at all easy to find a four-gear P38 diff in my experience, but you can always buy a two-gear diff (which is much easier to find and cheaper) and rebuild it with a Ashcroft ATB or an Ashcroft four-gear centre. This may even work out less expensive. Worth bearing in mind as an option.
A quick look on Ebay reveals stacks of two-gear diffs at prices from £90 to £140, and a couple of four-gear diffs at £240, and another four-gear at £350.
Post #927854 30th Oct 2021 5:57pm
Sam smith
Ok great thank you both so much for the info! That’s a great idea I shall look into that
Post #927886 30th Oct 2021 10:24pm
