Home > Maintenance & Modifications > Rear exhaust mount
Rescue01
Rear exhaust mount
Looking for some advice. 2011 2.4puma 110. Rear exhaust mount snapped this morning and I’ve cable tied it on for now. I can’t get under it till next week. So it’s the rearmost mount that’s connected to the rear crossmember. Is this mount meant to be welded or bolted to the crossmember? Also is it an item I can purchase? Also any recommendations as to where.
I’m working all weekend so just want to see if I can order a bit just now.
Thanks for looking.
Post #927673 29th Oct 2021 9:23am
Dinnu
I am not very familiar with 110 chassis, but my TD 90 has the welded bracket (as all model years) and a bolt on bracket. It is part 11 in below link. But the mount would probably bot be in the correct position anymore.
https://www.lrworkshop.com/diagrams/land-r...r_53434#11 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #927677 29th Oct 2021 10:36am
Dinnu
A picture, from a 90 with 2 hangers, not best angle to view though.
Post #927678 29th Oct 2021 10:38am
rallysteve
Actual hangar is bolted on, hopefully it is this bit that has broken rather than the bracket on the chassis (see Dinnu's pic above which is essentially same as a 110 one). See here for the part (no. 8 )
https://www.lrworkshop.com/diagrams/land-r...stem_45012
Cheers,
Post #927686 29th Oct 2021 11:25am
Rescue01
Thanks all that’s great. I hope it’s just the bracket and not the chassis mount.
Post #927692 29th Oct 2021 12:03pm
Hufflepuff
I'm late to the party, but here are some snaps from the rear of my Richards Chassis v8 110 for reference:
The peculiar stainless steel bracket going down to the exhaust came with the exhaust kit itself (double S exhausts) and I would expect your mount to the bracket to be different. The chassis bracket is welded in place on mine for reference. 2005 Td5 90 XS
1989 V8 110 CSW
Post #927853 30th Oct 2021 5:46pm
Rescue01
Thanks all. Part ordered. I’m off on Thursday so hopefully it’s just a case of bolting on the new bit. If not I might be asking for recommendations for a decent mig welder. 🤣
Post #928170 2nd Nov 2021 7:42am
