Home > V8 > My V8 Swap (Toyota 1UZ-FE)
Page 1 of 6 123456>
LJMARSDEN
United Kingdom 2006 Defender 90 Other HT Java Black
Hello All,
Thought I'd begin the thread early before all parts are in my hands.
Got a few things to iron out and discuss before I get going anyway.
Part List
Winchester Gears TDI R380 w/ 5% taller 5th, HD Bearings + Cooler
Winchester Gears 1.2 TDI Transfer Box w/ ATB Diff
DW250iL Universal 250l/h external pump
Ashcroft Adapter plate
LOF 300tdi Clutch kit
Speed Hut gauges (Eventually)
Loom from Pheonix Engine Mangement (Link Extreme ECU)
I will slowly add to this thread as time goes on but it will be somewhat quiet for a while as I'm only purchasing parts and or making them at the moment.
Thumbs Up 4.0 V8 Defender 90
My Instagram
Post #927555 28th Oct 2021 1:18pm
LJMARSDEN
Made up a design for my fuel sender mount in the td5 tank
Thought I'd save the monies making one instead of using a standard LR item
Will be using a length of corrugated plastic piping as the return feed
It'll be just two 9/16-18" for the plumbing which should be big enough to feed the pump
the WEMA sender has a standard SAE 5-hole pattern - Which I haven't seen before (Its split by 72 and 68 degrees... not a PCD)
please make any suggestions as I'm no mechanic but do just have some engineering back ground Thumbs Up
 4.0 V8 Defender 90
My Instagram
Post #927558 28th Oct 2021 1:24pm
Defendermatt
United Kingdom 1989 Defender 90 Other SW Bonatti Grey
I would recommend sticking with the Land Rover unit as I struggled to find a sender unit that would match up with the instrument cluster. 1989 90 4.3 V8
2012 L405 OF
2014 D4 HSE Lux (SOLD)
2015 90 HT (SOLD)
@d9o.mf
Post #927880 30th Oct 2021 10:27pm
LJMARSDEN
I've seen a few that'll fit with the standard hole size and black/ white theme, just the illumination is an issue at the moment.
Wema do their own, Duratec seem fine too at a similar price. both have black bezels too.
And plenty of other aftermarket brands available. I don't mind spending the time to find the right one for me. 4.0 V8 Defender 90
My Instagram
Post #927885 30th Oct 2021 11:23pm
LJMARSDEN
Picked up the Motor today:
Its a 97 1UZ non VVTI
Getting just a little bit excited now... Rolling with laughter
Will begin the strip down soon 4.0 V8 Defender 90
My Instagram
Post #929547 12th Nov 2021 10:12pm
Timbo
England 2008 Defender 110 V8 Petrol USW Tonga Green
Thumbs Up Look forward to seeing some progress Smile
Post #929549 12th Nov 2021 10:28pm
LJMARSDEN
Bit of a photo dump of my weekend by weekend progress...
Nothing fun or exciting - just stripping the engine down and rebuilding the top end.
Still got to wait for Winchester gears to confirm an order for the box and TC.
 4.0 V8 Defender 90
My Instagram
Post #933319 12th Dec 2021 9:35pm
LJMARSDEN
I've got to investigate that head, looks like its gotten quite hot. I reckon the headgasket not a channel being blocked at the minute. 4.0 V8 Defender 90
My Instagram
Post #933329 12th Dec 2021 10:50pm
There’s a lot of bits here! Stick with it.
Post #933342 13th Dec 2021 7:32am
LJMARSDEN
Will do GREENI Thumbs Up 4.0 V8 Defender 90
My Instagram
Post #933405 13th Dec 2021 1:52pm
Timbo
Rather you than me mate! Look's fun and you've only just begun! Big Cry Did you see pheonix selling off some prewired looms? I think they had one for the ls400 Thumbs Up
Post #933490 13th Dec 2021 10:56pm
LJMARSDEN
True Tim Rolling with laughter
And no I didn’t - I’ll have to have a look. Thanks for letting me know Thumbs Up 4.0 V8 Defender 90
My Instagram
Post #933514 14th Dec 2021 10:23am
LJMARSDEN
Likkle more progress made this weekend
I polished all 32 valves lightly, just cleaning them up and making the surface much smoother.
Also lapped both heads too, that was fun… (still somewhat satisfying to be honest)
Now my next plan or task is to source the loom and ecu, then we can get the engine running outside of a vehicle
 4.0 V8 Defender 90
My Instagram
Post #934310 19th Dec 2021 9:42pm
LJMARSDEN
Some goodies finally arrived.
Got the ECU/ Loom being sourced this month too. After that, in march I will be purchasing the adaptor plate and 2.8TGV Clutch. Then we're ready to take the car off of the road.
Can't get over how good all this looks, Quality looks billiant from Winchester. Such a shame I won't be able to see it all when its in the car. Rolling with laughter 4.0 V8 Defender 90
My Instagram
Post #941810 9th Feb 2022 5:56pm
Timbo
Tidy! I still can't believe the R380 is longer than an M57 BMW gearbox but it obviously is as my bulkhead will testify Laughing lets see some action now mucker Rolling with laughter
Post #942248 12th Feb 2022 10:50pm
Page 1 of 6 123456>
