Home > Maintenance & Modifications > New to the defender world - advice on Mods.
moge
Morning,
I have finally done it, and brought a 2010 Defender 110 HardTop LWB.
Now the exciting part, what are the best brands to look when when modding it? With my OCD, i would like to keep everrything there same (where possible)?
Any guidence would be great.
J.
Post #927324 27th Oct 2021 10:51am
Bluest
I donโ€™t think youโ€™ll find one brand that covers everything. In fact Iโ€™d be wary of those. Better finding the specialist in that particular item.
My advice would be to sit back, relax and not do anything straight away (or at least nothing permanent or very expensive) and instead do loads of reading first. If you are anything like me, what you thought you wanted when first getting the car soon changes. 2007 110 TDCi Station Wagon XS
Post #927325 27th Oct 2021 11:04am
Race.it
Spain 2010 Defender 110 Puma 2.4 SW Alaska White
welcome, best advice would be before changing things, ensure that that vehicle works well, as you could drop 3K on a set of wheels and tyres and find out you need some suspension bushes, or other work like a clutch etc, so I would drive it like it is, and as items wear out then replace them with upgraded items. (well thats my plan, now how do I convince myself my seats are worn out and I need some Recaro sportster CS seats in my life Smile ) Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details
Post #927329 27th Oct 2021 11:43am
Dinnu
After you do what has been suggested above, then can share what mods you plan or you like to have.
I see that there are 3 mainstreams of mods...
Make it go faster, kind of the Bowler route
Make it look uuurrrmmmm strange, kind of the Khan route
And there is the proper 4x4, full offroad, mud plugging or rock crawler route. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #927336 27th Oct 2021 12:31pm
scotty38
England 2012 Defender 110 Puma 2.2 USW Aintree Green
Boring but I'd look at security options first.
Post #927340 27th Oct 2021 12:49pm
AT1963
United Kingdom 2006 Defender 90 Td5 Black LE Java Black
even more boring make sure serviced correctly and on time Shocked
Post #927354 27th Oct 2021 2:36pm
discomog
I'd go with what Scotty38 says about security. Otherwise you may not have a Defender to modify Cool Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #927371 27th Oct 2021 4:35pm
diduan
Bulgaria
Funny, this night I had a nightmare...I dreamed buying a set of big shiny wheels for the defender. When I saw them mounted I wanted to get rid of them but couldn't. Then I woke up. Phew... Defender 110 SW MY2011 2.4tdci decat, no EGR
Jeep Wrangler YJ 1990 4.0. Front 78' Dana 60, Rear CUCV 14 bolt
Post #927380 27th Oct 2021 5:12pm
L110CDL
Another one for security first and then drive it for a while to see if you need / want to change anything Thumbs Up Clayton.
Keeper.
Post #927457 27th Oct 2021 9:44pm
nitram17
Re: New to the defender world - advice on Mods.
moge wrote:
Morning,
J.
I would start with the steering lock adjustment : http://defender90xs.blogspot.com/2013/11/s...tment.html
Post #927544 28th Oct 2021 11:15am
I Like Old Skool
United Kingdom 1994 Defender 110 300 Tdi ST Coniston Green
Steering stop lock adjustment is a good call, but aim for 5mm clearance instead of 15mm.
Also check brakes condition/function, handbrake operation, wheel bearings, grease propshaft splines and ujs, check swivels contain oil or grease, check/replace Fr & Rr diff oils, check/replace transfer box and gearbox oils, change engine oil & filter, inspect/replace air filter, inspect/replace ancillary belt. Not sure for later engines but for TDI engines REPLACE timing belt even if previous owner/seller says it has been done, unless you really, really, really believe them and still like to gamble! Flush cooling system and refill with the correct antifreeze/coolant.
Most of the above are routine or essential service items but many owners seem to treat them like mods that are optional or might get done in the 'future'. Doing these can go a long way to making sure you are not left stranded at the roadside with an even bigger expense. Remember, 'Chrome don't get you home!' and flashy mods look shjt when you are on the back of a tow truck... Thumbs Up
Post #927591 28th Oct 2021 4:13pm
Race.it
Love it ๐Ÿ˜‚๐Ÿ˜‚๐Ÿ˜‚.
I did most of the maintenance before I started to buy the shiny stuff I am now on my second round of maintenance but also more shiny stuff.
Some stuff was needing to be replaced so I upgraded it at the same time as replacing. Searching for my first Defender...and started just as Covid hit, so talk about timing.
Post #927604 28th Oct 2021 5:09pm
