Home > Wheels & Tyres > What’s the widest tyre on an 18” Bowler
Grenadier
Quite like the wide stance on a Def. Not silly wide like beaded wheels, just a little bit. I’m currently running 265/65s on the Bowlers, 18”, what’s the widest I can pop on under ‘normal’ usage? Can I go to 275? Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #927144 26th Oct 2021 6:59am
How wide are your wheels? That's the deciding factor for tyre widths. Darren
Post #927157 26th Oct 2021 9:00am
SJM2018
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Aintree Green
I think Bowler state they can take up to 285, but the tyre will also likely state the range of wheel widths they will fit.
BFGoodrich Ko2 LT285/65R18 would be my choice - I know slightly wider than you want, buy why not go all the way!! 2011 CSW XS 90
Post #927171 26th Oct 2021 9:32am
camelman
The bowlers are 8 inch wide so will take a 275 or 285.
I used to run 305s on my 16x8 mach 5s with no problem.
They are et15 however so the wider sizes will increase the chances of rubbing on full lock so might need some adjustment
Post #927175 26th Oct 2021 9:38am
DAZ110
Grenadier, I think I would stick with the 265’s because of your possible snowy location, and to limit the chance of the tyres rubbing on the suspension. Tyre rubbing would probably p*** you right off.
Post #927179 26th Oct 2021 9:50am
Grenadier
Thank you all. In answer to various points, don’t want to go super large, because of issues as mentioned above (rubbing, turning circle etc) so 275 likely enough. With regard to snow, completely understand your thinking Daz, indeed we run thinner tyres on Mrs Grenadier’s TT, but at only 850m alt, and really only ever working/travelling in winter months to a max of 1500m on main (therefore usually cleared) roads, rarely do we have snow where thin tyres would be an advantage. It’s either permanent hard packed, or it’s cleared. In between when it’s falling and the tyres usually do the job.
Think I’ll take a punt on 275. As for which brand, currently running KO2s but thinking of swapping to Pirelli ATR+. Better manners for the non winter months, full winter tyres for when it’s colder. Don’t go off road often enough to warrant anything really gnarly as most off roading I do is dry gravel, dusty and rocky alpine tracks. No mud. No sand. Having said that, do still like the look of them. Tyre fitter is going to order one of each in so that I can compare when mounted. Thumbs Up Monsieur Le Grenadier
Post #927260 26th Oct 2021 9:26pm
