![]() | Home > Series Land Rovers > wheel cylinder troubles |
seriesonenut Member Since: 19 Nov 2014 Location: Essex Posts: 1230 ![]() ![]() |
Hi
Hope someone might be able to give me a steer with a wheel cylinder problem on my Series One (1957) ![]() Click image to enlargebrakewvf by Richard Holmes, on Flickr Today I set about changing the off side rear wheel cylinder ( no drama) then the front. The system is 'empty' of fluid (all lost through the rear cylinder). The new front Delphi cylinder seems to have a too powerful spring. The pistons are being held in by the rubbers, I fitted it but it is forcing the shoes out to max. Had a nightmare getting the drum off again. Am I missing something obvious? The rear cylinder acted as expected, pistons pushed back and gently expanded. Any suggestions, do I have a new but duff cylinder? 1984 One-Ten CSW 2010 XS USW (sold) 1957 Series One 88 diesel 1958 Series One 88 4x2 |
Shroppy Member Since: 25 Feb 2016 Location: Shropshire Posts: 866 ![]() ![]() ![]() |
I presume you have the 10", single leading shoe set up? If so, does the shoe-shoe spring not keep the pistons 'returned' in the cylinder? I've never had a wheel cylinder with an internal spring strong enough to over power the shoe spring.
Assuming you have all the springs in their correct places then I can only think that you either have a duff (overly powerful cylinder spring) wheel cylinder as you suggest or a particularly weak shoe spring. A photo would help ![]() Series 2 109" Series 1 80" |
